View Poll Results: How ur car doing?
Perfect
60
32.61%
Some minor problems
101
54.89%
Too many problems
21
11.41%
What car????? oh, u mean my paper weight
1.09%
Voters: 184. You may not vote on this poll
How is ur 4th gen doing? Poll
Old Dec 23, 2003 | 08:00 AM
  #41
MN_Maxim's Avatar
Warped rotors, rusted exhaust, bad O2 sensors, CEL (Knock sensor), axle click, clutch worn, door handle chipped. Other than that...car's in perfect shape with 102k miles.
Old Dec 23, 2003 | 09:48 AM
  #42
Bonka's Avatar
Schnell kaputt
Pretty much all of the NON mechanical issues on my Max bother me to some extent but I'm first and foremost worried about mechanical problems..
Awful squeek when I first turn over the engine, usually comes and goes so I have no idea if the starter needs regreasing or if the belts need adjustment/replacement
The steering wheel is slightly off center to the left after I adjusted the tire pressure so I'm hoping an alignment will cure that..
Engine's a bit noisey on idle..again hopefully either it's the belts or the timing chain making noise..another on and off issue and I can't hear it unless I'm standing around the hood..
Brakes are worn to a nub!! Needs new pads and probably new rotors..woops
Probably other small mechanical issues I haven't found but it's been good!
Old Dec 23, 2003 | 12:29 PM
  #43
Max240's Avatar
replaced tranny and then clutch about 4 months later. the car has 118k on it. other than that, i love it.
Old Dec 23, 2003 | 06:41 PM
  #44
RA030726's Avatar
I'm nutty for Nissans
I think the tranny leaks b/c i never replaced the seals from the new axles. I broke the doors locked confirmation blink when using the remote. Antenna is sticking. Replaced all O2 sensors, knock sensor, muffler, rear struts, brake pads, its all the stuff thats supposed to wear out. This is why I stand behind Nissan. I cant wait until the rest of the exhaust rots through....warpspeed here I come. I just wish i took better care of the paint!
Old Dec 23, 2003 | 08:25 PM
  #45
BOZOnPJs's Avatar
i voted perfect, although, my only complaints are the cheap driver's seat there's a broken bracket, and the paper thin metal that dings even if you just tap it. other than that i love my max.
Old Dec 23, 2003 | 09:06 PM
  #46
KWheelzSB's Avatar
Originally Posted by Maxima10to1
. . .This is why I stand behind Nissan.
. . .& this is how Nissan stands behind you:
You Nissan
Old Dec 24, 2003 | 06:17 AM
  #47
Maxima99SE's Avatar
will fly for food
You Nissan
hahaha, very very true
Old Dec 24, 2003 | 09:05 AM
  #48
Wrightsfd's Avatar
Where do I begin?
Replaced clutch at 90K and stock flywheel had hot spots and needed replacement (previous owner must have beat the crap out of the clutch) but I was putting in a Fidanza anyway so it worked out fine. I have a knocking noise from the front sustpension on bad roads, had to replace O2 sensor due to cheap Mexican gas, warped front rotors (I've never done that on my 9 previous cars and still trying to figure it out) and the aftermarket pads squeal like a city bus, Nissan black paint sucks (especially the bumbers) the dash squeaks in two places, and the Bose buttons keep falling off. Other than that, no problems at all! I still would not sell her either.
Old Dec 24, 2003 | 09:54 AM
  #49
maxfun's Avatar
112000, no problems
I love this car.
I set the bar with my 92 accord at 265000 mi.
so far so good.
Old Dec 24, 2003 | 09:57 AM
  #50
Taken2DaMax's Avatar
It's funny how some times we as enthusiasts overlook the problems with our car and just buy performance parts for other parts of the car instead of recognizing the dilemma at hand.
Old Dec 24, 2003 | 08:36 PM
  #51
scottcarlsonMAX's Avatar
115k and running great except for minor electrical problems(clock, foglight burnout) and an CEL code of 1302 MAP Baro/solenoid...which I have no idea what to do with????
Old Dec 24, 2003 | 09:19 PM
  #52
outsider's Avatar
one naggin problem that stupid thump at idle sometimes really **** me off
Old Dec 25, 2003 | 12:46 AM
  #53
Midknight MAXX's Avatar
Rear calipers were sticking (replaced)
Knock sensor went bad (replaced)
EGR solenoid (dealer replaced)
Starter whines
A/C compressor noisy
Wheel stud broken off (replaced)
Power steering tensioner bolt broken (my fault)
Transmission drain plug won't come out
Some fuel ventilation crap (dealer replaced)
Not the worst but enough to keep me from buying another Nissan.
Old Dec 25, 2003 | 04:07 AM
  #54
Ludacris's Avatar
80k miles
-320 miles per tank..only acceptable to me
-Plenty of rattles (probably gonna double the amount when I lower on sprints/agx)
other than that..doing fine (knock on wood)
Old Dec 27, 2003 | 12:27 AM
  #55
1996blackmax's Avatar
The only problems I had started when the car was over 100k. I changed a bad KS earlier this year along with the water pump, left wheel hub and bearing, right wheel bearing, left axle (my fault for not noticing my ripped CV boot) and AC compressor. That is it for now, the car still pulls great, I am very happy with it .
Old Dec 27, 2003 | 01:37 PM
  #56
Max240's Avatar
well said.
Old Dec 27, 2003 | 02:08 PM
  #57
Keith P's Avatar
Bought at 37,000 miles. Replaced O sensor at 38,000. 4 yr.s, 80,000 miles and one speeding ticket later, 23 mpg, a few odd rattles, muffler leaks; flowmaster or magnaflow or cheap??? Air dam needs paint. Right CV joint used to make noise until I put on the new springs and struts and bushings. The only question is the clutch, which is original.
Old Dec 27, 2003 | 10:59 PM
  #58
(_8*(l)Homer's Avatar
Mine is perfect, other than: Small dent under left side rear door window. Broken heater vent near clock (my fault) and steering wheel is crooked after right side cv shaft replacement.
Old Dec 28, 2003 | 04:02 PM
  #59
Armelius's Avatar
doing great with 220,000 replaced abs brakes/rotors, starter, right cv joint
1 position of fan ac/heat doesn't work
get egr/ks code after resetting computer after about 80 miles
Old Dec 28, 2003 | 05:16 PM
  #60
radar912's Avatar
I am the 2nd owner of a black 99 gle, purchased at 120,000 kilometers, now approaching 170,000. I have changed the front brake pads, other than that, had to reset an ecu code for transission, never reappeared and have had to reset the airbag light a few times, recently during damp weather, prolly a connector somewhere. The car is stock but pulls well, I drive it fairly agressively at times but don't abuse it. Do regular maintenance, all myself, feed it regular gas (supposed to be bad but doesnt affect it so far) and run synthetic oil. Very happy with it, everything works as it should, no interior problems, a few dings in the body, will paint in a year or 2. I plan to drive this car for at least 3 more years, she has not let me down yet, very happy.
Old Dec 29, 2003 | 12:27 AM
  #61
Update. I just ordered a new radiator, should be in tomorrow. I noticed it had a leak on Saturday morning . I was taking the kids up to the mountains to play in the snow and decided to check under the hood.
I am still happy witht the Max though .
Old Dec 29, 2003 | 01:31 AM
  #62
RastaManMax's Avatar
1) Alternator Recall
2) New rotors, pads all around (79K)
Has 84kms on it right now 1997 GXE
LEMAR
Old Dec 29, 2003 | 05:10 AM
  #63
KWheelzSB's Avatar
Originally Posted by Armelius
doing great with 220,000. . .
There is a simple part under the passenger side dash (forget what it's called) you need to replace to correct this problem. It's about $28 at any Nissan dealer & can be removed/installed in under 3 mins. It looks like a small circuit board with a wiring harness plug attached to it. It's held in place by two screws.
(If you look up underneath the dash, you'll see what I'm talking about).
Old Dec 29, 2003 | 09:20 AM
  #64
mdell's Avatar
95 gxe, 110 k
2 starters
4 cv boots
1 knock sensor
1 O2 sensor
1 thermo sensor
1 injector
1 head light
engine speed meter shot
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
