Idle at 550 rpms?
Old Dec 22, 2003 | 04:46 PM
Pogophil's Avatar
Idle at 550 rpms?
My parents just bought a 97 Max SE. It idles at 550 rpms.
1) Is that normal?
2) How do I adjust it upwards?
Thanks.
Old Dec 22, 2003 | 05:06 PM
NissanMasterTec's Avatar
no it is not normal
to fix it you need to adjust the IAC valve to the correct base/curb idle setting/percentage
Old Dec 22, 2003 | 05:58 PM
CullenJ76's Avatar
your parents just bought you a max and you already have three cars?
Old Dec 22, 2003 | 06:05 PM
Ant96GLE's Avatar
Maybe its his parents car?
Old Dec 22, 2003 | 06:25 PM
gto400no1's Avatar
Out of curiosity could idling at 550 rpm cause a problem with gas millage cuz my car idles that low and i get bad millage, just trying to find out if the two problems are related in anyway.
Old Dec 22, 2003 | 06:32 PM
CullenJ76's Avatar
appologies. misread
Old Dec 22, 2003 | 06:41 PM
outsider's Avatar
same here i also get a thump once in a while at idle still
it really annoying me
and i cant seem to find a mechanicc who knows what to do.
Old Dec 23, 2003 | 05:51 AM
Kevlo911's Avatar
Kevlo for President
try to clean IACV, Throttle Body, and change the air and fuel filter if you have not done so. How to's for all can be found in the 4th gen how to's; link in my sig.
Might have to look in hte 60k Service in the how to's for some of these
Old Dec 23, 2003 | 06:27 AM
BOSS
I don't know about autotragics, but if the idle is at .5 RPM on a 5-spd then it is perfect. An idle of anything above a .7 RPM on a 5-spd is way too high and considered bad.
Anyway, about the thump that some of you hear when at idle is very common due to what else if not weak and slightly deteriorated ignition coil(s). A defective coil always causes these random thumps at idle.
Old Dec 23, 2003 | 07:04 PM
outsider's Avatar
i changed the coil though
maybe another one is goin out
sigh
Old Dec 23, 2003 | 08:16 PM
aarrr22's Avatar
the same thing just happened to me when i diagnosed my ecu , and ended up not switching it off. the car ran idle at .400 rpms, and i bugged out. switched the self test machine to the middle, and ide ran back to normal.
Old Dec 23, 2003 | 11:14 PM
Maxima99SE's Avatar
will fly for food
i get that thump too!!!! it really makes me want to shoot somebody...
Old Dec 24, 2003 | 04:01 PM
outsider's Avatar
haha owned my nissan weak coil
Old Dec 24, 2003 | 06:02 PM
EZ's Avatar
EZ
It could be that a sensor has gone out. The check engine light doesn't detect bad sensors every time so if you have a bad O2 sensor, you could be getting weird idleing and bad gas mileage for example. I had both symptoms, replaced both oxygen sensors in the front and everything went back to normal. I'm not saying that this is your problem but it is a possibility.
Old Dec 25, 2003 | 10:37 PM
Pogophil's Avatar
yeah, it's my parents' car. i'll try the IAC cleaning -- that was my first inclination too, but i'll try it when it's warmer out....
thanks.
Old Dec 26, 2003 | 08:07 PM
elevit's Avatar
Sorry, what are the normal rpms when idling (with a break pedal pushed, auto transmission)?
Is 600 also too low?
Thanks,
Eugene.
Old Dec 27, 2003 | 04:29 AM
twiggy144's Avatar
1996 and later auto tran: between 600 to 700 rpm, while shifter in P or N , no load on the engine, when engine is warmed up.
Old Dec 27, 2003 | 09:22 AM
tynant's Avatar
Why is a high idle bad for 5 speeds? I had a new (used-45k mile) engine installed several months ago...I had a bad idle (and a host of other problems) and felt it would be easier and cost less in the long run to just get a new engine....anyway, this engine idles very high! fully warmed up, no throttle movement, its just above 1000 rpms. when driving, if you put it into neutral before a light or whatever, the idle drops to 1500 rpms for a second and then to just above 1000 rpms. I had an auto max prior and the idle was nothing alike. What could be wrong with this engine? Or does it just need simple maintainance like described above? TB cleaning etc...? thanks!
Old Dec 27, 2003 | 08:25 PM
twiggy144's Avatar
start with turning the idle screw on top of the idle air body
Old Dec 28, 2003 | 08:39 AM
twiggy144's Avatar
1996 and later models manual tran idle speed spec: between 525 and 625 rpm
Old Dec 28, 2003 | 11:10 AM
tynant's Avatar
Why is a high idle bad for 5 speeds? I had a new (used-45k mile) engine installed several months ago...I had a bad idle (and a host of other problems) and felt it would be easier and cost less in the long run to just get a new engine....anyway, this engine idles very high! fully warmed up, no throttle movement, its just above 1000 rpms. when driving, if you put it into neutral before a light or whatever, the idle drops to 1500 rpms for a second and then to just above 1000 rpms. I had an auto max prior and the idle was nothing alike. What could be wrong with this engine? Or does it just need simple maintainance like described above? TB cleaning etc...? thanks![B]
would 2 bad O2 sensors, something wrong with the EGR sensor or valve or whatever and a hole in my b-pipe account for this?
Old Dec 28, 2003 | 11:54 AM
CullenJ76's Avatar
are those specs from the FSM. I left mine at my garage
Old Dec 28, 2003 | 12:32 PM
twiggy144's Avatar
from Haynes Manual
Old Dec 29, 2003 | 11:58 PM
boyzindahood978's Avatar
Hmmmm...I don't know what happened. My car idled at 800 rpm (95- 5 speed). I decided to clean my throttle body. It was pretty dirty. After reinstalling everything and starting up the car, my car now idles at 1000 rpm!!! Everything was put back together so I don't know whats wrong. I'll try adjusting the Iac valve. What else could be wrong?
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
