LED size for light ring around ignition?
Old Dec 23, 2003 | 01:12 PM
Stringztoo's Avatar
What size is that LED that illuminates the ring around the ignition?
Old Dec 23, 2003 | 04:01 PM
aznprid972's Avatar
the blub size are #74 blubs i think... very tiny.
Old Dec 23, 2003 | 06:19 PM
Stringztoo's Avatar
are you sure?
Old Dec 23, 2003 | 06:22 PM
geo1317's Avatar
Originally Posted by Stringztoo
are you sure?
its 74.....
Old Dec 23, 2003 | 07:04 PM
Maxtank's Avatar
it's a 12V lamp, not an LED
Old Dec 23, 2003 | 08:34 PM
KsuMax's Avatar
Cheesing away...
Is the keyring light always suppose to be on? Because it's not for me.
Old Dec 23, 2003 | 08:42 PM
polishpunk68's Avatar
only when the dome light is on i think
Old Dec 23, 2003 | 09:40 PM
JeremyMarkham's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2449992571
Is this the right bulb? Also, is the current bulb green colored, or is the actual ring green?
Old Dec 23, 2003 | 10:28 PM
Stringztoo's Avatar
The bulb is white with this cheap rubber "condom" thingie over it to make it green. The ring itself is clear so I wanna make it deep blue.
Old Dec 23, 2003 | 10:34 PM
geo1317's Avatar
http://autolumination.com/74.htm
Old Dec 23, 2003 | 11:12 PM
Y2KSESteve's Avatar
Originally Posted by geo1317
Thanks!
Old Dec 24, 2003 | 01:52 AM
Just bought a Super White #74 from autolumination and had a question...how easy is it to access and change the bulb? How to?
Old Dec 24, 2003 | 04:57 AM
Stringztoo's Avatar
VERY easy, just remove the 6 screws on the bottem of the steering column and when you pull it apart there is a round piece of plastic that surrounds the ignition switch. Pop that off and simply slide the "light ring" off the ignition switch and twist the light socket to access the bulb.
Old Dec 24, 2003 | 08:27 AM
Jepht20's Avatar
Custom User Title...
i only need to remove the closest screw under the steering colum and that gives me enough room to pop off the plastic piece around the ignition. i can pull all the rest out no problem.
Old Dec 24, 2003 | 09:08 AM
Tyrexx's Avatar
Blue LED all the way!!!
Glue Tin-Foil to the "frame" that holds the bulb and around the bulb it makes it shine through better.
My Blue LED shines bright all the way around, the picture doesn't show it well
Old Dec 24, 2003 | 11:04 AM
Cool beans...I thought about going blue but since I have done my gauges, door lights, map light, and dome light all Hyper white I figured I would go that way with the ring too...
tsi6001
Oct 3, 2022 10:23 PM
trasmadean
Jan 20, 2018 05:05 AM
maximaham
Aug 20, 2015 10:23 AM
spidgeon
Aug 18, 2015 05:46 AM
maxima297
Aug 3, 2015 12:50 PM
