Will I need camber adj bolts to align the front end after H&R drop
Old Mar 1, 2001 | 10:23 AM
plrod Black 95 SE's Avatar
I'm going to be getting an alignment soon and would like your opinion/s on whether or not it will be possibe to have it done to spec without camber adjusting bolts.
Old Mar 1, 2001 | 10:38 AM
BSwithTF's Avatar
They can align it without them.
I put H&R's on my fiances car and took it down to get it aligned and they were able to do it without and camber kits. They even did my car with Sprint's on it and that's a 2" drop. So unless they didn't get it right on our cars a regular alignment should do the trick for yours.
Old Mar 1, 2001 | 04:07 PM
dch95's Avatar
Camber question
No you will not because camber is not adjustable. Although it may appear OK to the naked eye, once you drop the car the camber will change as well as the toe setting. Camber can only be adjusted by installing camber bolts (which I think is a waste of money) or go to NAPA and buy either 1/2inch or 12mm bolt of the same length and shank as the strut/spindle attach bolt. Only one per side is needed and it is used in place of the top strut/spindle point. This will allow for camber to be adjusted. Toe in/out is the only adjustment that can be made without mods.
boomerbrian
Nov 8, 2015 05:10 PM
JoshG
21
Sep 4, 2015 09:04 PM
official_style
Aug 29, 2015 10:10 AM
Samedi
Aug 12, 2015 01:54 AM
laparka66
Aug 6, 2015 09:36 AM
