Hub/Wheel Bearing Gurus needed
![](https://maxima.org/forums/images/smilies/support.gif)
I recently had a terrible noise from my front passenger wheel. See this thread . I had my wheel bearing replaced and the problem is fixed BUT the shop says I need a new hub. They couldn't get one until next week so they just put the car back together. My question is do I REALLY need a new hub. The bearing made noise (although a terrible noise) about 5 times over the course of a week. My new bearing has a 12 month/12k mile warranty on the old hub. Should I replace the hub or just gamble that the bearing will last. I looked at the bearing replacement howto and it looked too complicated for me so I am guessing the hub will be just as bad if not worse.
Another option would be to get a replacement hub from a salvage yard.
Could very well be bad. I remember reading that if you need to move the car with NO axle in place that you MUST put at least the axle hub and bolt in place or it will ruin the bearing. I doubt that you did this,but it does indicate that they can go bad.
Mike
Mike
Having just changed the bearings myself, I don't think you need to change the hub.
Did they say WHY the hub needs to be replaced???
The hub is just a solid piece of steel that the bearing is pressed onto. The bearings take all the wear, not the hub. I've ran with deteriorating bearings for a couple of months before replacing the bearings and I just changed the bearings only. There was nothing wrong with the hub.
I'd ask the shop for the reason why they think the hub needs to be replaced and post the reason on the forum.
Thats exactly right, The shop is probably trying to rape you for some more money! lol. Hubs rarely ever go bad, as a matter of fact people would probably only change a hub if the studs were messed up (even though you can change each stud individually) or if the hub was physically/structurally damaged.
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
TonyJr
08-20-2015 12:14 AM
