should i buy suspension mounts/boots? & camber kit?
Old Dec 29, 2003 | 07:33 PM
wrongway15's Avatar
i am hopefully installing new suspension soon...probably kyb agx and tein s.tech springs. should i buy the mounts/boots that i see on tirerack? they set would be $92 for all four (kyb brand) also is there anything else i need?
and about camber kits...can i but the eibach one ($25) on tirerack or do they make brand specific ones?
thanks
Old Dec 29, 2003 | 08:10 PM
vsamoylov
i got a chamber kit from tirerack.com for my suspension. it made my tires be all even and look good and not cricked. worth your money if drop is significant height.
Old Dec 29, 2003 | 08:52 PM
GeeShack's Avatar
What is considered to be a asignificant height, cause I'm throwin in my new suspension next week. Maxspped springs and Tokico shocks ( 1.5"-front, 1.3"-rear) Do I need a new camber kit?
Old Dec 29, 2003 | 09:38 PM
wrongway15's Avatar
sounds significant to me....grab yourself a camber kit
Old Dec 29, 2003 | 11:36 PM
PeTeRtheEaTeR's Avatar
for maxspeed, Tein H. Tech, Eibach, H&R, and other springs that only drop u 1.5 in the front and 1.3 in the rear, YOU DO NOT NEED A CAMBER KIT! I got maxspeeds on and that thing doesn't even looked dropped, especially with 15" sawblades. Plus the wheels are striaght. People usually get camber kits with Sprints, and Tein S. Techs. Some with Progress. But Maximas don't easily camber so GeeShack, you're pretty much set with Maxspeeds but the Tokico Blues are bad shocks with lowering springs. Get at least KYB GR-2's and if you can fork in a little more money then get the AGX. Get some dustboots and bumpstops if your stock ones look like they're in bad shape (torn, flimsy, etc.) Good Stuff in here ~~~> http://maxmods.dyndns.org/?MaximaHandling
Old Dec 29, 2003 | 11:51 PM
Max Noob's Avatar
dont waste your money on camber kit.. i have maxspeed cut 1 coil and i still dont need a camber kit..if u want it that bad..buy the camber bolts. way cheaper.
boots.. get them from summitracing.com.. Rancho strut boots.. like 10 bucks.. cheaper that kyb. made of polyeurathane not cheap rubber.. jsut liek kyb boot.
cut your stock bumpstop in half and reuse old strut mounts.
i would invest money and buy new strut bearing though..35bucks from dealer.
matts95max
Apr 23, 2025 10:44 AM
Jamie Bolus
Sep 13, 2015 05:56 PM
Violator
Sep 9, 2015 10:14 AM
A32goldylocks
Sep 2, 2015 06:39 AM
