97 GXE Keyless Entry
I searched the FAQ for this...
How do I tell if my car has keyless entry? I recieved no remote when I got it, the dealer has no idea (shocker) and some dude on eBay is selling key fobs stating they will work with ANY Maxima. I am thinking you need to have some security package to have that feature, but I am not sure how to tell if mine has it. Thanks!
yup
Power seats usually indicate the presence of the Package.
You might even have the security system as well. Check if you have a little red light thats labelled "SECURITY" next to your steering wheel (left).
The dealer will/should know...there is supposed to be some grey box that is located near the front or in the trunk(???) that indicates the existance of the keyless entry system or where the harness plugs in.
Actually, do a search for this topic, cuz i remember it was brought up about a few months ago with the EXACT details.
Hope this helps (sorry for my lack of knowledge hehe)
Though any good Nissan mechanic at your dealer SHOULD know if its installed or not...did you buy this car from a nissan dealer? or a 3rd party?
Look for the Multi-Remote Control Relay
The manual refers to the keyless remote feature as the Multi-Remote Control System. It uses a Multi-Remote Control Relay. Look to see if your car has this relay.
1) Open the trunk. Remove the trunk compartment floor carpet and the fiberboard spare tire cover. These are removed with your hands; no tools are required.
2) Remove the cardboard trunk trim which surrounds the latch mechanism. The five plastic fasteners which secure it are quarter-turn latches and come loose easily when turned with a Phillips head screwdriver.
3) Look at the area of the trunk latch mechanism, made visible by removal of the the trim panel. Locate electrical connector T5. This is a brown plastic connector with 6 terminal positions. If your Maxima does not have the keyless entry feature you will find connector T5 taped up so it does not rattle, but with no relay plugged into it.
4) Reinstall all the trim you removed.
This whole operation should take three minutes.
Little red light
Originally posted by Matrix
... You might even have the security system as well. Check if you have a little red light thats labelled "SECURITY" next to your steering wheel (left). ...
No keyless entry
Thanks to all who responded, I have no keyless entry...no blinking LED, no box in the trunk...
Am I to understand that all I need is the box? Would I need a relay/actuator for the trunk, or could I just not use that feature. Thanks again for all the help!
It's not that simple
... Am I to understand that all I need is the box? ...
red light
Daniel, do you have the security system installed in your car though? (hence the light)
Because I was under the impression (at least for my model year), that the security system package would automatically include the keyless entry. I.e. you could not get the security system without also getting keyless entry.
At worst, you could probably take it down to a Nissan dealer and have a mechanic try to activate a remote on your car, if it fails, then there is no keyless entry
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
Plain Jane
wow!
I never knew that Maxima's were sold without power antenna!
This is all news to me.
But then again, I also thought all Maxima's had wood trim. Well, so the sales rep told me. He had me test drive a model with the wood trim, and he said, you can buy the exact car you test drove for 35,000 (CDN). So I agreed. Then we went through the usual bargaining process, and he said he would bring it down by $500.00. Sensing that they wouldnt go any lower, I bought it. When i drove it home, I noticed NO WOOD TRIM. When I called the guy up he said that the wood trim was a $500.00 option. GEE I WONDER HOW YOU GUYS REDUCED THE CAR BY $500.00 COINCIDENTALLY ENOUGH.
Needless to say, I hate the Nissan dealers...I bought the car back in 1997 when Maxima's were selling so poorly many people didn't even know what a Maxima was.
Oh well, thats my daily rant.
tarun900
19
12-20-2021 06:57 PM
