Making clears stay in
Old Mar 2, 2001 | 01:25 PM
98BlaximaSE's Avatar
I just put my clear front bumber lights on,but the side parking lights don't stay in to tightly. I read how to do it on maximadriver.com, but I can't really seem to get under the fender like how he explains it. Is it possible to tighten them from the fog lights? Or any other ways?
Old Mar 2, 2001 | 01:55 PM
Riot^'s Avatar
the only way
I think that is the only way to do it.
My friend did it, he didn't have a problem on his. I am waiting for my clears to be shipped to me, then I'll let you know for sure
Good luck
Old Mar 2, 2001 | 02:20 PM
dmbrazilian's Avatar
What I did was wrap some of that plastic that they come wraped in on the ***** and made them tighter and I have had them in for 4 months and have had no problems yet....
Old Mar 2, 2001 | 02:24 PM
What I did was wrap some of that plastic that they come wraped in on the ***** and made them tighter and I have had them in for 4 months and have had no problems yet....guess its kind of a lazy way but hey it works...
Old Mar 2, 2001 | 02:27 PM
seven's Avatar
here's the solution.
if you compare the clears with the factory, you'll see that the piece that plugs into the little hole for the sides are a little bit shorter. that's why the factory sides snap in while the clears don't. i had my sides come off while driving on the highway, so i had to solve the problem! just loosen that plug piece and unscrew it until its just as longer or longer than the factory piece. also i found that the factory plastic holder fit the plug better than the aftermarket. when you put the clear sides on, make sure it snaps in place.
good luck
Old Mar 2, 2001 | 02:28 PM
buss95max's Avatar
maxfaqs at max.org...it shows how to secure it from the inside...thats how i did it..and i havent had any problems..
Old Mar 2, 2001 | 02:47 PM
Re: here's the solution.
good luck
Yeah I noticed that, I did this before, but didn't hear it click in to place. I haven't driven with them in yet, but I want them to be secure before I do. I'll try the plastic around the plug, that sounds like a good idea.
Old Mar 3, 2001 | 08:51 AM
Ramius83
Basically, you might want to try securing them from the inside. Then, no matter how hard of a hit you take, they will NOT pop out. Also, this makes them less prone to people taking them if you live in a bad area. I do not know the exact web site that I got the info from, but they are out there. Try doing a search or something on the Org. Take it easy
Old Mar 3, 2001 | 09:32 AM
psu max's Avatar
yea securing them from behind the bumper is really the only way to keep them in ...
when i did it, i had one hell of a time getting my arm up underneath the fender, but its doable. you need to unscrew 1 screw on each side and then you will be able to jam your arm up under the fender
your best bet is once u got your old lights out and your arm up under the fender is to have someone else guide ur hand to the right spot to secure the lights
Old Mar 3, 2001 | 03:47 PM
1Phat Max's Avatar
GLUE 'EM
they use to pop out every time i drive (new YOrk ****ty) the best and easy solution i found was i had some glue sittin around for computers so i glued it with that. and now no PROBLEM!
Old Mar 3, 2001 | 03:59 PM
Ravq's Avatar
I agree with using the OEM plugs and screwing them into the clear lenses. I also used some weatherstripping around the perimeter of the lens assembly just far enough back so that when I installed them it would fit snug and you can't see the weatherstripping.
Old Mar 3, 2001 | 04:20 PM
gtr_rider's Avatar
192.168.1.1
This might help you a lot <A HREF=http://integra.vtec.net/geeser/megamax/clear_corners.html>Clear Corners Installation></A>
Old Mar 3, 2001 | 04:30 PM
Mad Jap's Avatar
Ditto here, too.
I wrapped the bubblewrap around the part that goes toward the back of the car, and it's on pretty snug.
DJLAX152
May 4, 2021 11:46 AM
Maxima30
Sep 7, 2015 06:13 PM
