Input on Engine Knocking and Oxygen Sensors?
Old Jan 5, 2004 | 01:38 PM
kgutty's Avatar
I have a '95 GLE with about 160,000 miles. My "check engine" light recently came on and after doing the diagnostics I was told that my Engine Knocking sensor (P0325) and one of my Oxygen sensors went bad. I was told I needed to replace these sensors (both Oxygen sensors) for roughly $900 parts and labor. I was hoping to get some additional insight from other Maxima owners/mechanics to see if I should/need to invest this much money to replace these sensors.
My car is running fine, I do regular maintenance (oil changes, tune-ups, etc), there's no engine knocking (I have always used premium gas), no other odd noises, and my exhaust/emissions appear to be fine. My car is getting old and I'm just looking to get as much as possible out of it before I look to buy a new Maxima in a couple of years. If anyone has any opinions/insight whether or not I should do this maintenance...the input would be greatly appreciated.
Thanks,
Kory Gutrich
Old Jan 5, 2004 | 01:47 PM
DAVE Sz's Avatar
Hooooooonda.....
oxygensensors.com for the O2 sensors. They cost about $60 each and you can change tem yourself. The knock sensor code is cause by the O2 sensors
Old Jan 5, 2004 | 05:30 PM
twiggy144's Avatar
$900 ! insane!
Old Jan 5, 2004 | 06:56 PM
bobjohnson's Avatar
Blazin......
Whats funny twiggy is most older baby boomers just suck it up and pay the mechanic to do this..
Ever thought about starting your own Maxima Specialist Shop to make some of this money$... Hey it's a business.. dont you get a tax cut too then wooohoo
Old Jan 5, 2004 | 07:18 PM
ARVY's Avatar
Agree u!!
Just change the O2 sensor and reset the ECU, then the KS code will gone.
Old Jan 5, 2004 | 09:54 PM
-=PK=-Maxima's Avatar
holy cow......$900?!? i cant believe my eyes/hears
Old Jan 5, 2004 | 10:36 PM
ABK's Avatar
ABK
$900 he better put in some 24k gold 02 sensors in my car
Old Jan 6, 2004 | 02:03 AM
Max Noob's Avatar
wth.. 900??? dood gimme..$130 for 2 o2 sensors .. ill put them in for you for $50 bucks, lunch and a beer. ok mayb 2 beers.
if in fact your knock sensor is bad too.. which at 160k it probably is.. ill change that for another beer. u can buy one for 90 bucks off ebay.
Old Jan 8, 2004 | 11:03 AM
kgutty's Avatar
Thank you all for your comments!
Yeah...I agree...I think that guy was smoking something for a $900 job to replace a couple of sensors.
I'm going to look to replace the 02 sensors myself and then see if the Knocking sensor needs to be replaced.
Thanks again for all your advice.
Old Jan 8, 2004 | 11:18 AM
Stephen Max's Avatar
Originally Posted by twiggy144
$900 ! insane!
Run...do not walk...away from that shop and never return!
Which O2 sensor code did you get? If it is 0707 (rear heated O2 sensor), you don't even have to replace the sensor if you don't want to except to get rid of the light. The rear O2 sensor plugs into your cat or right behind it and is used to monitor the cat. It does not affect closed loop operation of your engine like the two front O2 sensors do.
Old Jan 8, 2004 | 11:26 AM
Kevin Wong's Avatar
Has anyone had any luck with NGK O2 sensors? I'm very skeptical with Bosch or any other German-made electrical items on Japanese cars. I've noticed that Bosch tends to be great on Euro and some domestic cars. NGK and Denso tend to work best on Japanese and some domestic cars. I was pretty bummed when my stock sensors went out at 40K miles.
Old Jan 8, 2004 | 11:41 AM
DAVE Sz's Avatar
Hooooooonda.....
BOSCH makes the OEM sensors for our cars. Use their sensors, but not their spark plugs.
Old Jan 8, 2004 | 01:58 PM
MadChef's Avatar
If you take your car to any Nissan dealer, and the codes say you need an O2 sensor and a knock sensor, you will find out that they are going to charge $900 regardless of where you go. It sucks, but if you don't want to do it yourself then I guess what else can you do? =)
Old Jan 8, 2004 | 02:02 PM
UncleMax98's Avatar
If you don't want to do it yourself, get the O2 sensor first and let a local shop install it. Should be about $65 for labor. Maybe the KS will go away after the O2 is replaced. Check ECU to be sure.
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
mvm062
Nov 30, 2020 09:00 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
