New Y-pipe help? Am I screwed?
I've got a '96 SE with 133,000 miles on it. I need to replace my "front pipe" which i've come to learn is a y-pipe that i can buy online for 1/4 of what the mechanic wants to charge me. i'm just worried that i'll need more than the y-pipe itself. Will i be ok with just ordering the y pipe from Budget Exhaust, and will i be able to pass inspection in Massachusetts? any other m*******s around who might know?
Originally Posted by happyricefob
if CA people with intake y-pipe catback can pass without a problem, you shouldn't have a problem in MA. good luck
thats not true at all. i failed 2 times and and i know a lot of ca people who failed also . i drove around for 45 mins and let it idle for 10 mins before getting on the machine. if you have never changed your cat, i'm almost positive that you would fail.....that is if you live in cali i dunno what your state. but you also have to keep in mind caliornia has one of the toughest smog regulations in the US.
I am also considering an aftermarket Y-pipe but skeptical about it because of the strict CA emissions test. So I was thinking about something during my commute back home this evening. How about taking a Budget Y-pipe, for example, to a good custom exhaust shop and have them make the holes where the O2 sensors go. Not sure how much this would actually cost but I'm going to ask around here in San Fernando Valley and see where it goes. Any inputs or thoughts?
-Dennis
-Dennis
Ahhh. Budget y-pipes have holes for 02 sensors, they just don't have precats
There are two diffent pipes one for california people (cali spec), and other everybody else (fed spec). It depends on your car and what kind of y-pipe it needs
-Dennis
-Dennis
Are they manufactured by Budget too? And are there gains from these pipes as well? If not, I'm sticking with my old ones since there's nothing wrong with them at all.
Originally Posted by BOZOnPJs
just get a CA spec y pipe. they make those.
Well I just moved to Cali from Nevada. I bought the car from an Arizona owner and the car was originally bought by that owner in Arizona so I cannot say that its Cali-spec. However, the only non-stock thing that's in it is a K&N cone filter w/ a MAF adapter. And soon, I'm making a home depot midpipe for it. I still haven't registered it at the DMV here but have to get it smogged first. So the midpipe and y-pipe is pending til it passes smog, plus I have to resolve this EGRC solenoid valve issue that's tripping the CEL. BTW, I have three O2 sensors.
Originally Posted by IwANnAMaX96
Just because he lives in CA doesnt necessarily mean he has a Cali-spec max...
Originally Posted by ABK
Yeah he is right go jump underneath the car and check out how many 02 sensors you got.
ABK reminds us of why we want to change the (stupidly designed) ypipe.
The only reason that anyone needs to change the y pipe is damaged. What is wrong?
You have three total? Or 3 on the y pipe? If you've got 2 in the y pipe, 1 cat, 3 total, then you've got a cali spec. Check the FAQ, you can double check with the vin too, if you are not sure. Also, do you actually care about getting another 10 hp or so? Is it worth the extra worry about smog, or hissing noises at high rpms, etc? If you just want a pipe that works, and aren't into modding your car, check the classifieds on the org, and ebay. I've seen factory pipes going for as little as $20. If you just want to get your car fixed, just get a used stock y pipe. Save yourself $170.
god damn it. Just read the F.a.q. All you have to do is check under your hood, there is a metal tag. Underneath your v.i.n is another row of numbers. The 12th letter will be v. for fed spec. If not it's canadian or cali spec.
I just checked mine, and now I'm certain that my Max is a V = Cali spec. I never really bothered checking this but thanks to you guys, I became curious enough to check it. Question: is California more strict with Cali spec Maximas? Lets say that Maxima has all the bolt on mods: Y-pipe, B-pipe, intake, etc. Would this Maxima most likely pass the visual and smog inspection? What's everyone's experiences on this?
I have a cali-spec car, and I live in Massachusetts. Is there any difference between the cali-spec and fed-spec? Are cali slower or anything? And will this limit me from getting any aftermarket parts or anything? And do I need to get a cali-spec y-pipe even if I don't live in CA? Thanks, Steve
lrb6805
09-17-2015 04:49 PM
