just wanted to make sure these numbers are right
Old Jan 5, 2004 | 08:56 PM
JS MAX's Avatar
Alright I plan on using these 3000mcd leds for my climate control
http://www.superbrightleds.com/leds/b3023_specs.htm
these say they run a typical 3.5v forward voltage at continuous current of 20 ma. If I wire them in parallel, it requires around a 106 ohm resistor but the closest is 120 ohm, would this work ok and be bright enough?
OR could I get away with using a 100 ohm resistor or would it be too much for the 4 volt max handling?
Old Jan 5, 2004 | 11:07 PM
Nismo's Avatar
100ohm and 106ohm isnt much difference since resistors are not 100% accurate in the first place. If in doubt, Its better add more resistance than less.
Old Jan 5, 2004 | 11:44 PM
Maxtank's Avatar
how many are you wiring together in parallel?
MatthewsMaxima
Sep 11, 2015 03:21 AM
JoshG
21
Sep 4, 2015 09:04 PM
Turbobink
Aug 15, 2015 07:20 AM
BassAddictJ
Aug 4, 2015 11:38 AM
