2000 engine and tranny in the 1999?
Old Jan 7, 2004 | 05:55 PM
PmpLuxCEO's Avatar
Just came back from reading the FAQs and I noticed that nobody has done this and nobody deems it feasible to do it because it has no value.
Well, let me explain my situation.
I blew my 38K s/c engine. I was planning on swapping in this junkyard 2000 engine, which has the same layout as the 4th gens, except it has a different intake manifold and different exhaust, thus allowing it to have 222 hp.
Now, will my s/c kit work on this engine? Will I have problems installing this engine in my car? Will it fit under the hood with the new manifold? Will it run?
I currently have a blown 1999 I30 engine.
Any help will be much appreciated.
Old Jan 7, 2004 | 06:24 PM
DAVE Sz's Avatar
Hooooooonda.....
For the last time. The intake manifold will not clear the hoood, this is a small problem. It also won't clear the firewall, not enough room for it. There is no point to this really, only bigger injectors I believe but according to this http://cgi.ebay.com/ebaymotors/ws/eB...tem=2452038198
4th gen motors have "The engine is a '99 with 3000 miles on it (pre K motor so it has the thicker block casting and stronger rods and forged crank".
Old Jan 7, 2004 | 06:53 PM
BEJAY1's Avatar
Conecarver
I know this has been talked about before but I didn't want to search right now.
Aren't the cams or something else slightly diff in the 2K engines? Wasn't there something besides the manifold and exhaust giving the +32/37hp. I haven't looked at the graphs but if one could make it fit wouldn't it be much better than the MEVI solution?
Old Jan 7, 2004 | 09:18 PM
DAVE Sz's Avatar
Hooooooonda.....
Adaptor for the engine mounts and it would probably fit. Move them up towards the front a bit and it could work. I think they also used some different materials for some odf the internals to make them lighter or smoother or something.
Old Jan 7, 2004 | 10:15 PM
vsamoylov
back to this again. My bro and I completed this swap except the intake manifold on the car is off a 4th gen.
Internals are different also. Lighter and car accelerates and runs smoother also.
Old Jan 8, 2004 | 06:26 AM
krismax's Avatar
Father of the 00 VI
If you took the head of a 96 and used the 2000 block what would be the snares or problems with that?
Old Jan 8, 2004 | 06:57 AM
NmexMAX's Avatar
dot dot dot ...
Tha sorta defeats the purpose of the swap, because the IM is one of the better parts of the VQ30DE-K
Old Jan 8, 2004 | 11:44 AM
vsamoylov
thermostat is the next problem cause you have to relocate it.
Old Jan 8, 2004 | 11:46 AM
DAVE Sz's Avatar
Hooooooonda.....
Since you have a 2k block why don't you get a dyno to see if it makes 4th gen or 5th gen power. You say that it feels smoother and faster but that means nothing. Just a suggestion to end all this.
Old Jan 8, 2004 | 02:27 PM
krismax's Avatar
Father of the 00 VI
So with that ,the thermostat would be the only problem. Why cant you just set it up like a 4th gen ? Is the block area cast different there?Is it the same setup as my 96 but in a different spot . If you can give answers to these questions that would great. Thanks
Old Jan 8, 2004 | 03:33 PM
NmexMAX's Avatar
dot dot dot ...
If you're going to plan on doing a big project like taht just do the famous DB Martin 3.5 stroker idea. . .
Old Jan 8, 2004 | 03:45 PM
bobjohnson's Avatar
Blazin......
I did read a few weeks back in the Boosted fourmn of someone who DID swap a 2000 engine in a 95. He just reversed 1 side of the Motor mounts and it worked perfectly he said.
I believe his New REAL prob was getting new axels for the front.
Anyone know where this Swap thread is???
Screw the hood problem . Get ya a Damn scoop like me or get something bigger.
Old Jan 9, 2004 | 04:22 PM
krismax's Avatar
Father of the 00 VI
bump 123456
pktaske
May 6, 2016 07:49 AM
seesole
Sep 14, 2015 12:38 PM
pktaske
Sep 4, 2015 08:40 AM
trungg86
Sep 4, 2015 04:58 AM
Lowered_a33
Sep 1, 2015 07:49 PM
