antifreeze qn.. please help
Old Jan 8, 2004 | 05:48 PM
fishpony's Avatar
ok i need to flush and change my radiator and everything and put new antifreeze in because i busted the upper radiator hose. well do i put in the orange dex-cool prestone antifreeze or should i put in the normal green prestone? i can't find this anywhere and i'm goin out in like 15 min to start work.
Thanks in advance
Old Jan 8, 2004 | 05:50 PM
sharkulator's Avatar
What color was in it when you got your ride? Mine was green, so I use green prestone.
Old Jan 8, 2004 | 05:51 PM
fishpony's Avatar
well it was orange when i got it but i've heard not to use the orange because it's for gm vehicles
Old Jan 8, 2004 | 06:43 PM
Look at this:
http://www.injuryboard.com/view.cfm/Topic=1095
http://www.geocities.com/b_gillie/dexcool_problems.html
Old Jan 8, 2004 | 06:45 PM
I wouldnt use dex-cool. GM owners shouldnt even use dex-cool.
Old Jan 8, 2004 | 06:54 PM
fishpony's Avatar
so is it o.k. that i switch from the orange stuff to the green stuff? will i have to flush it out completely not just the radiator? Does anyone have a link to where the other drains are located at? guess i'm gonna have to go another couple days with some very dilluted orange antifreeze and high temp duct tape on a hose.
Old Jan 8, 2004 | 07:00 PM
I know it is in the Haynes Manuel on how to do it. It might be in the FAQs as well.
Old Jan 8, 2004 | 07:03 PM
fishpony's Avatar
well i'm just asking that if i don't do a complete drain, and just drained the radiator and then just flushed the entire engine with water and drained it and repeated a couple times, if it would be ok because there would still be a little orange left in it when i add the green
Old Jan 8, 2004 | 07:14 PM
To be honest take it to a mechanic who can do this procedure my old man told me about, I dont know the name but I suppose it is as good as a flush basically they use the new stuff to push out the old stuff. Once the fluid coming out is the same color as the stuff going in, you are good to go. This is a real non technical explanation for the procedure. I know they do it with transmission fluid.
Old Jan 8, 2004 | 07:48 PM
mzmtg's Avatar
Minister of Silly Walks
Green green green!
Our cars were designed to use green.
Old Jan 8, 2004 | 08:14 PM
fishpony's Avatar
cool thats what i bought!
fastcarny
Oct 12, 2015 07:06 AM
RWCreative
Sep 21, 2015 11:01 AM
Ramius83
Dec 7, 2003 09:33 AM
SamMan23
Mar 20, 2003 09:43 PM
