Antenna adaptor?
Old Jan 9, 2004 | 08:16 AM
95MaxSE's Avatar
Antenna adaptor?
Hi all,
I'm trying to replace the original radio/casette in my 95 Maxima with a radio/CD from a 2000 Sentra. The two square connectors on both units match perfectly. But the antenna connectors do not.
The antenna socket of the Maxima unit has 2 (two) holes in it, and a snap-on latch on the side. The socket of the Sentra unit has only 1 hole and no snap-on latch, therefore can not receive the antenna cable.
Am I out of luck? Is there a solution?
Thanks all,
Sam
Old Jan 9, 2004 | 08:33 AM
BLACKonBLACK98's Avatar
Former Vendor
they do make antenna adapters. whether or not they make the one you need, i don't know. try crutchfield.com or similar sites, or if you want to stay local car stereo plus is who i deal with in houston. if all else fails, splice em.
Old Jan 9, 2004 | 08:37 AM
95MaxSE's Avatar
Thanks.
Which adaptor do I need?
What's the name/number of your local car stereo shop?
Sam
PS: I think I'll pass on the splicing ;-)
Old Jan 9, 2004 | 09:07 AM
erty67's Avatar
Decal Specialist
if the sentra has a standard antenna plug, you can get an adapter from Wal-mart for like $10. The maxima had a double antenna. You'll only get use of one of them, but it should work.
Old Jan 9, 2004 | 09:43 AM
95MaxSE's Avatar
Thanks erty67.
I don't really understand the above statement. It sounds like I will NOT be using the full capacity of the Maxima antenna. If so, my reception will be WEAKER, correct?
Sam
Old Jan 9, 2004 | 09:47 AM
erty67's Avatar
Decal Specialist
Originally Posted by 95MaxSE
Thanks erty67.
Sam
yea, that was basically my point. I have a aftermarket HU and I only get to use one antenna. It's not bad.
Old Jan 9, 2004 | 11:10 AM
ABK's Avatar
ABK
Is the sentra headunit powered? Because you got SE and I think that one comes with BOSE. You might run into so problems if you the sentra headunit is powered
Old Jan 9, 2004 | 06:49 PM
Former Vendor
Thanks.
i bought one today.
car stereo plus
713-861-1211
@ 610 & 290
just explain to the owner what you need, he'll know what your talking about.
Old Jan 9, 2004 | 06:54 PM
Former Vendor
this is correct, if you have bose and the sentra unit has its own output. they do make an oem intereface, but i haven't heard anything good about them. if you have bose, you'll want to replace the speakers and there are some wiring issues. e-mail me if you have questions. admin @ 20somethingwheels.com (- spaces)
Old Jan 9, 2004 | 09:22 PM
ManualMaxima's Avatar
5th Gen till she dies!
could you not use the connector and just wire the wires up to each other? or are they different?
Old Jan 9, 2004 | 11:22 PM
Broaner's Avatar
2060lbs and falling...
Splicing antenna wire is a superb idea. Antenna's are intended to increase reception.
Old Jan 10, 2004 | 01:07 AM
Former Vendor
yes. but theres alot of wires to pick from. too much work.
Old Jan 10, 2004 | 06:04 AM
95MaxSE's Avatar
i bought one today.
car stereo plus
713-861-1211
@ 610 & 290
Thanks.
I just bought one yesterday from Walmart, $8.00. I installed and it's worked BUT:
It only uses the rear windshield antenna. The powered mast antenna is disabled, it does not even come up anymore. Is there way to make it work the other way around?
Sam
Old Jan 10, 2004 | 11:35 AM
Former Vendor
Thanks.
Sam
thats not so much because of the antenna adapter but because of the head unit. i'm guessing the sentra did not have a power antenna? i ran into this problem too, but didnt worry about it since i'm shaving everything anyway. something about a remote power lead to the antena motor.
Old Jan 10, 2004 | 12:12 PM
JeremyMarkham's Avatar
Why did you opt for a 2000 Sentra radio? Isnt the shape of that radio some what round? I really am more curious about the first question though...
Old Jan 10, 2004 | 12:13 PM
skiboarder72's Avatar
ik I had to buy a antenna adapter when I put my new HU in. 11$ at circuit city
Old Jan 10, 2004 | 01:30 PM
erty67's Avatar
Decal Specialist
Thanks.
Sam
sounds like the power antenna isn't getting voltage on the remote lead. my only guess would be to get a male to male antenna adapter to hook up the rear window antenna....or cut the wire that goes to the power antenna and hook it up to the ignition wire. Then the antenna will be up whenever the car is on.
9aj9
Apr 5, 2020 12:11 AM
chisam14
Nov 6, 2018 08:56 PM
magiconthetire
Oct 26, 2015 09:03 PM
DBear
Sep 14, 2015 08:33 PM
Violator
Sep 9, 2015 10:14 AM
