hp loss
Old Jan 11, 2004 | 01:59 PM
collin's Avatar
hp loss
how much hp am i lossing since i have a bad knock sensor
Old Jan 11, 2004 | 02:00 PM
CullenJ76's Avatar
change it.......
Old Jan 11, 2004 | 02:22 PM
UncleMax98's Avatar
Not sure if any one has dynoed a car with bad KS. If you are driving with a bad KS, change it and you will be impressed. Instant power and lots of it... I guess a bad KS robs you about 10 to 20% power and causes a lag in throttle response.
Old Jan 11, 2004 | 03:34 PM
soulrupture's Avatar
Thats true I've been noticing power loss and lag and I just checked the ecu and found that nasty 0304 code.
I reset it and took a 6 minute ride up/down hills. Now i get 0505 no problem. I will keep checking it.
if it happens again I'm changing it.
Old Jan 11, 2004 | 04:51 PM
Shift_Power's Avatar
Oh it will happen again, trust me. Happened to me too. I replaced the KS and that ended up not to be the problem. It was ignition coils despite me getting a 0304 code. So it could be your coils too, how many miles on the engine?
Old Jan 11, 2004 | 05:00 PM
95,540k miles. I thought the coil problems were only on the 97 and up max. I got a 95.
Old Jan 11, 2004 | 09:58 PM
DR-Max's Avatar
Just changed two of the coils in my 95. You can test them for proper resistance, it should be 0.8 ohms. If greater, then you'll need to replace them. Also check for cracks around the boot. They cost around $80 each or more at the dealer. I paid $65 at Autozone. An org member paid $59 at the dealer.
Old Jan 11, 2004 | 10:26 PM
vipervadim's Avatar
I like Maximas
A bad knock sensor gives your engine's maximum hp output at a mere 160 hp at peak rpms with slow low-end acceleration. so you get a noticeable power loss.
at courtesy nissan ignition coils cost me $56 and $58 each (front and back).
A new knock sensor is about $120.
courtesy nissan is a good place, 1-800-527-1909 talk to Bryan and mention Maxima.org for a discount.
-Vadim
Old Jan 12, 2004 | 12:50 AM
Eric425's Avatar
540 thousand miles? Wow, you must take great care of that thing. I've never heard of a max with so many miles that kept on running... These engines must be durable.
Old Jan 12, 2004 | 12:59 AM
sleepermaxima's Avatar
Hehe... I hope he meant 95,540 miles not a 95 max with over HALF A MILLION miles.
Old Jan 12, 2004 | 02:31 AM
Eric425's Avatar
yeah, that makes more sense. Maybe he didn't know what k stood for. 1k= a thousand. 100k= a hundred thousand. 95,540k= ninety five million, five hundred forty thousand.
Old Jan 12, 2004 | 09:20 AM
LOL I meant to say 95,540 miles.
if only they made cars that last 540,000 miles
Or 95 million miles lol
TallTom
57
Oct 14, 2025 05:16 PM
zmcneely13
Sep 26, 2015 02:26 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
magneto112
Sep 10, 2015 12:52 AM
FlaMark
Aug 21, 2015 11:06 AM
