Clutch Problem Please HELP!
Old Jan 11, 2004 | 10:08 PM
Maximus_95's Avatar
ok, here's the story.
i was on the freeway, i tried down shifting from 5th to 4th.
it goes in to 4th but....it doesn't do anything. its like 4th gear is in neutral but its not! it is in gear. well....anyways....i get off the freeway.
all gears are working except 4th.
after a few signal lights, it does not go in 1st or 2nd, only third.
so i drove all the way home taking off on 3rd gear, eating up my clutch.
so gears that are working is 3rd, 5th and Reverse.
1st and 2nd gear, it does not even go in.
4th gear, it goes in but it does not take off or anything, its like neutral.
can anyone help me??? does anyone know whats wrong!
starting to have too many problems.
Old Jan 11, 2004 | 11:06 PM
Maximus_95's Avatar
help? anyone?
Old Jan 11, 2004 | 11:53 PM
budha56's Avatar
Wish I could help. Sorry. Here's a bump though.
Old Jan 12, 2004 | 12:24 AM
Maximus_95's Avatar
bump................
Old Jan 12, 2004 | 12:54 AM
sleepermaxima's Avatar
Did you hear ANY funny noises while shifting or driving previously?
Have you recently had work done to the car?
Does the shifter feel sloppy or stiff (or normal)?
How is the tranny fluid level?
Without knowing the answers to any of these questions, I would look under the car and locate the bar that resides above the catalytic converter. This is the shift control rod. Make sure the joint between the shifter lever and the rod is not loose. Then visually inspect the shift control rod for things such as cracks and lodged road debris. Move towards the transmission and check the other end of the shift control rod for play or damage.
Also, make sure the support rod is not loose and interfering with the shift control rod. This is located above and parallel to the shift control rod.
Other than that, I don't think there is much you can do besides have the tranny cracked open.
I hope this helps.
D
Old Jan 12, 2004 | 08:05 AM
nismos14's Avatar
§è~® f®ÈÄk
if u check all of that out and u dont see anything wrong i'd be very close to assuming ur trans is toasted and you're going to need a rebuild or a new trans.
Old Jan 12, 2004 | 09:01 AM
ABK's Avatar
ABK
I don't think it's a clutch. It's really weird. It's like somehow your 4th gear got grinded off. I would say take it to really really good mechanic that won't BS you. Maybe there is easy fix to it.
Old Jan 12, 2004 | 11:16 AM
SiCkBLaCKMaX99's Avatar
Welcome To The World Of New Trannies Same Happened To Me Butinn Third U Need To Go To The Tranny Shop
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Excalibur23
Oct 13, 2015 04:33 PM
pears
Sep 18, 2015 05:25 AM
slowlifer
Sep 8, 2015 05:53 AM
