Right Headlight not working
Old Jan 11, 2004 | 11:47 PM
Max-2-GTR's Avatar
When I started my car today, I saw the blue light in the dash telling me the high beams are on but they weren't so I was wondering what it means. The right headlight does not work since today high beam or not so I don't think the bulb is the problem since it would be a weird coincidence that both filament burned at the same time. Is there a electrical problem?
Old Jan 11, 2004 | 11:50 PM
blackmax96ny's Avatar
i had the same problem on my car and i still do. its an electrical problem for me and its probably an electrical problem for u. one of the wires that was attached to the headlight burned for some reason.
Old Jan 11, 2004 | 11:57 PM
Max-2-GTR's Avatar
And you didn't fix it yet?
Old Jan 12, 2004 | 04:19 AM
ManualMaxima's Avatar
5th Gen till she dies!
are you using higher wattage bulbs? you harness is burned out and it wil not be fix till you put a new one on. i have delt with this 3 times till i fianally put the stock bulbs back in.
Old Jan 12, 2004 | 11:35 PM
Max-2-GTR's Avatar
No I'm just using phillips bluevision and have them on for almost a year...Is there any reason that can cause that or is it really a burnt harness?
Old Jan 15, 2004 | 09:40 PM
Max-2-GTR's Avatar
Is it a DIY job? I don't know with the electrical stuff but don't want to go to the dealership. How much can I expect at the dealership to replace the harness?
Old Jan 15, 2004 | 09:46 PM
DAVE Sz's Avatar
Hooooooonda.....
Took you 3 sets of bulbs? Wow.
Mine just stopped working one day and started blowing fuses. Put the stockers back on and everything is fine.
Old Jan 15, 2004 | 09:57 PM
Cool J's Avatar
i just put some sylvania extravision bulbs in my max. is this going to cause me problems down the line?
Old Jan 15, 2004 | 10:10 PM
DAVE Sz's Avatar
Hooooooonda.....
if they are stock wattage then they will be fine. Make sure you don't touch the bulbs with your fingers, that will cause the bulb to BLOW eventually.
jerrod99_se-l
Aug 27, 2015 08:27 PM
asianstyle
Aug 24, 2015 08:29 PM
KristyKarina
Aug 23, 2015 09:53 AM
Samedi
Aug 12, 2015 01:54 AM
kenc15
Aug 5, 2015 08:29 AM
