AE Headlights Just Finished!!!!
Old Jan 18, 2004 | 02:15 AM
  #41
apbrian112's Avatar
hmmm... another project to do while i'm on leave. i'm gonna spend my 2 weeks leave from iraq working on my max. yay!
Old Jan 18, 2004 | 07:59 AM
  #42
Nismo3112's Avatar
Custom User Title
Did you just set the light on the grill thing? Sorry for the stupid question, i just want to make sure I dont ruin it.
Yeah I just placed it on the grille. (the top one if you have two grilles).
Originally Posted by Mr****s95SE
did you do a preheat cuz i think the write up is without one.
I did preheat the oven.. Put the headlights in, preheat (2-3 min), then anohter 5 min.
Old Jan 18, 2004 | 12:24 PM
  #43
Taken2DaMax's Avatar
i was reading the VQpower write up. They said that "painting" masking tape is to be used. Can i just use pain ol' masking tape? Is there a difference?
Old Jan 18, 2004 | 01:21 PM
  #44
95CustomMaxima's Avatar
No difference, just as long as it keeps paint from getting on the inner reflection housing(chrome).
-Nick
Old Jan 18, 2004 | 02:38 PM
  #45
Nismo3112's Avatar
Custom User Title
I think there is a difference..The painting tape will have less sticky stuff so when u peel it off, you wont bring anythign along with it..I used regular tape on my parking lights and when i peeled off the tape, some chrome peeled off too
Old Jan 19, 2004 | 09:42 AM
  #46
hotmax97's Avatar
will i don't know if this was ask before but when you are finish do you have to put them in the oven
again to heat up the glue to put them back together
Old Jan 19, 2004 | 10:01 AM
  #47
Before I got finished painting them. I put them in the oven again to soften up the glue. It's easier for you to push them together. I also used silicone glue to make sure that no water would get in. You don't really want condensation getting in. Then you gotta start all over again...
Since I also just finished my AE headlights I really recommend not to use reagular masking tape. That sticky part stays on the light plus I noticed that when i ripped of the tape some of the reflective stuff came off. Should of used the painter's masking tape. AAAAHHHHGGGGGG!!!!!
Old Jan 19, 2004 | 10:19 AM
  #48
Black95Se's Avatar
Lookin' good.
Old Jan 19, 2004 | 10:47 AM
  #49
DR-Max's Avatar
Question for those that did the AE mod: Did you guys notice the beam pattern of each headlight narrowed? Observing the pictures, you guys are painting the sides of the reflectors. Anyone made some beam comparisons between AE'd out and non-AE'd out headlights? Just curious.
Old Jan 19, 2004 | 12:42 PM
  #50
MrDicks95SE's Avatar
Offset Is Everything.
i think there is a slight difference in beam pattern cuz mine is a little bit narrower. its more focused instead of spread out.
Old Jan 19, 2004 | 12:56 PM
  #51
Stringztoo's Avatar
-Nick
There is a difference, masking tape is more permeable to paint and will most likely seep through. Also, the glue used in painter's tape is different so there is no residue after it is removed, hence the fact you use masking tape for one purpose, and painter's tape when you are painting anything.
Old Jan 20, 2004 | 08:13 AM
  #52
ohannon7's Avatar
Originally Posted by ABK
remeber to sprinkle it with some flour. Damn guys we start sounding like some idiots baking something, lol.
good stuff man.
Benny, I need to come by and take a look at your headlights. It looks like you did a good job. BTW-I passed you on Bandera yesterday....
Old Jan 25, 2004 | 01:03 PM
  #53
vsamoylov
When I did mine, I also took out that ring inside that goes around the bulb and now my bulbs are really bright and the pattern stayed the same. just got way brighter
Old Jan 25, 2004 | 02:50 PM
  #54
DR-Max's Avatar
Isn't that ring for the purpose of directing light from the bulb back towards the center (flat) part of the reflector then dispurses out to the rest of the reflector: up/down, left/right? Are you referring to the brightness of the bulb from outside your car looking at the headlights or from inside the driver side looking out into the road ahead?
Old Jan 25, 2004 | 09:56 PM
  #55
vsamoylov
I doubt that. it is there to lmit the output of the bulb. it got brighter in both ways
Old Jan 25, 2004 | 10:35 PM
  #56
DR-Max's Avatar
Very interesting...why would they put something there that would reduce bulb output, especially from 9004? If anything they should have tried to enhance its output for better road visibility. I might just do this mod. That ring screws in correct?
Old Jan 26, 2004 | 05:07 PM
  #57
vsamoylov
yes, the ring is screwed in place
Old Jan 26, 2004 | 06:00 PM
  #58
1FSTMAX's Avatar
1995 Maxima AE Headlights/Cornerlights:
[IMG]pic[/IMG]
[IMG]pic[/IMG]
[IMG]pic[/IMG]
The black is not nearly as black as it appears in the pics. I took this in my Garage because my car is now stored and wont be outside for another couple months.
-Nick
Wow good job, the clearance light and headlight look really nice.
Old Jan 26, 2004 | 10:46 PM
  #59
PEARLYI30's Avatar
how come when people do the AE mod they dont paint it the color of their car instead of painting it black?
Old Jan 26, 2004 | 11:02 PM
  #60
its called the ae mod so it looks like the ae car. black housing. not white, not red, not beige. black. plus if it was red housing, thatd look funky and a white housing wouldnt look to good either. it would be different, but not look good. black housing looks cooler anyways. its much more noticeable too.
Apr 16, 2020 05:15 AM
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Noela
Sep 26, 2015 08:22 AM
