MAF adapter
Old Jan 15, 2004 | 08:22 PM
hollaatchaboi's Avatar
MAF adapter
I just purchased an ebay BOMZ intake. The guy sent me the wrong MAF adapter. Where can i find an adapter for cheap? This shop charged me $40. That's ridiculous, thats almost how much I spent for the intake. Can someone help.
Old Jan 15, 2004 | 08:30 PM
or is there anything else that i can use to install the filter?
Old Jan 15, 2004 | 08:47 PM
NookieMax's Avatar
you could hack the stock piece
Old Jan 15, 2004 | 08:54 PM
also what size should the filter be? What size should the opening to go over the MAF be? Because i was sent a filter with a 3" opening and it goes inside the MAF i was sent with the intake. Isn't the opening of the filter suppose to go over the MAF?
Old Jan 15, 2004 | 08:56 PM
bqc's Avatar
bqc
if you have a bench grinder, you could grind down the square flange of the MAF so that it would become a round tube and your filter just slip right over it. The MAF screen will have to be removed also. That is what I did with mine
Old Jan 15, 2004 | 11:04 PM
Broaner's Avatar
2060lbs and falling...
I did that also, but you better be sure your keeping your max cause its a lot a $$$ to get a new one. A 3" filter should fit perfect on the hacked MAF. If not get the one from cattman.com.
Old Jan 15, 2004 | 11:41 PM
happyricefob's Avatar
V^___^V
ebay has cheap intake adapter...look around...
or follow brianv.net's ghetto custom intake adapter off the stock air box >> http://www.brianv.net/mods/filter/
Old Jan 16, 2004 | 09:26 AM
Vyrus's Avatar
eMail www.RedLineMax.com, it should be about $15.
-Cyrus
TallTom
57
Oct 14, 2025 05:16 PM
-ReLLiK-
Apr 29, 2016 06:25 PM
magiconthetire
Oct 26, 2015 09:03 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
