Power Steering Leak... *pics*
My max started leaking power steering fluid recently. I've read some threads that discussed a recall on 97 maximas that had loose PS hoses. My car's VIN falls out of the VIN # recall range but it's still a 97. I jacked up the car took the wheel off hoping to find a hose to tighten. I wasn't sure which hose I was supposed to try to tighten (anyone have a pic of the hose that needs to be tightened??) so I got under the car. While under the car I found this.
Chunk of rubber that was ripped:
Rubber was ripped and fell off of this:
More pics of the area:
Anyone have any info on what's going on here? Is that my leak? What is that rubber from? I did take my car to a mechanic and he said I needed a new rack and pinion.. 700 dollars.. =( I was hoping I could just tighten a hose.. =( I'm losing my job at the end of this month, company closing down. I don't want to spend the 700 if I don't have to.
ZuM
ZuM
my third gen was leaking fluid and I looked everywhere. I finally fount out I had knocked the resevoir with a wrench and the fluid was running down the hose out the bottom of the car. check the backside of the resevoir.
The resevoir for the 4th gen is on the passenger side... All the fluid is leaking on the driver side. I'll look anyway though.
You can get a rack and pinion for under a 100$ from www.car-part.com
or new one from here http://www.trademotion.com/partlocat...=6&catalogid=1
COOL!! So is the Rack and Pinion the same as the "Steering Gear" as I see it in the Haynes manual?
i have two brand new hoses i bought for my power steering leak, and it wasnt the problem. its the hoses by the radiatorish area. Let me know if you need them, cause i can sell them to you a lot cheaper than the dealership. They charged me 55 bucks for them!
ZuM
ZuM
ZuM
ZuM
Originally Posted by Phatmax98
Don't know if mine was leaking from there, but I did have a pad PS leak..took it to my mechanic that I trust very well..and he said new rack and pinion...cost me 750..but that also included new cv boots, bushings for the rack and pinion, and 75,000 mile maint....sucks but hopefully this isn't your case.
One day my car was parked outside and it leaked a good sized puddle. Maybe a 12 inches in diameter. My car has been in the garage not moving since and it's leaked a few drops. I'm guessing I will have to replace the whole rack and pinion. I think the rubber is just there to isolate metal on metal contact. I don't think it's a seal. I see a lot dirt stuck to fluid on top of the silver thing in the last pic.
Hey, I just noticed mine does that too. But doesn't leak when the car is sitting there. It just leaks when the car is on. I took my car to my shop and he said it might be my rack and pinion. He didn't know for sure, b/c we couldn't get my car on the lift. I think it's my return hose from looking in my Haynes book.
Zumble, can you give me a link or the range for the the loose hoses?
I just turned my car on and got a drip too! Just took the car off the jackstands and saw no fluid. Turned the car on to warm and I got a drop. =(
The PS return hose seems to be on the passenger side of the car along with he pump. My drip is coming from the driver side.
Here is the link:
http://forums.maxima.org/showthread....+Steering+Leak
Here is the link:
haha . . . i just have the same problem...
my mechanic told me i need a new rack & pinion too. . . he said it's a common problem with maximas. . .I've never heard anyone complain here but this thread makes me think . . .
i just keep adding fluid to it for now (too broke to fix it) . . . let me know if you fix it.
At this point it seems like I may just replace the rack and pinion. I'm going to try to find a 99 like kevlo suggested. I may end up with tighter steering. =) Anyone know if the 99 is a direct fit or not?
Originally Posted by Frank Fontaine
Did you feel any improvement to your steering? Just curious--the boots and new bushings are nice to have. But if all it did was stop the leaking, I'd rather just keep topping it off. I don't feel my 98 can justify spending nearly a grand on it when it hasn't even reached 90k yet.
I don't know if I'm imagining things, but after I got it done..the steering wheel didn't feel so loose...oh and I think I needed a new one anyway..my mechanic said the r & p was pretty messed up...I didn't really ask him how it was messed up...but I did have a rattling problem when I went WOT from a light..sucked..but now it doesn't do it
My leak is on my drivers side too. I'm not sure if you have a Haynes manual, but I'm looking at figure 17.4 on page 10-15. My leak seems to be coming from the return hose marked as A on that figure. I'll try and get my digital camera from my sister if you don't have that book. Just to describe where the leak is coming from. It's from around the boot where the steering column comes through the fire wall.
I do have the haynes manual. I'll take a look at the pic again and try to locate that hose. I'll get back to you. I had to take my car off the jackstands cuz I needed to drive it.. =P Haha. Lucky I have a hydraulic jack and electrics impact wrench. Car will be up again soon. =)
I got the digital camera and took the picture:
In that figure, my leak is coming from A, which they labeled as return hose. Is your leak coming from there Zumble?
I just checked mine again and I see fluid or signs of fluid from areas all around where that hose is. I turned the car on and watched for leaking and didn't see anything. The fluid pattern suggest either the fluid sprays from a certain area or it leaks down from a higher elevation. There is fluid in too wide and too far an area for a drip from that hose. At least thats the case for me.
ZuM
ZuM
Maybe you should try the no-leak ATF. Since we don't have real Power Steering Fluid( Nissan owners manula says to use ATF). I would buy some ATF and change the fluid. Buy the kind that says it stops leaks. Or synthentic one that says it will.
http://www.motorvate.ca/mvp.php/702
I guess I could try that next. Maybe my Redline Synthetic Power Steering fluid damaged the rack and pinion??
You put power steering fluid in hte car, NOT GOOD. Nissan recamends ATF Drexon II/III or equivlent. Flush Out your whole system and put some ATF in there and add 4-12 OZ of the ATF leak STOP. Maybe even a 1/4 of a quart of hte ATF leak. I see the some ATF with the leak stop in it and i see the serparate addive bottles. i would add moble 1ATF and some ATF leak stop stuff.
OH NO! SO that's the problem!!?? Who would have know we weren't supposed to put power steering fluid in the power steering!!!! =( Only tranny fluid I have is Mobil 1 synthetic. Think that will be okay?
uh oh....I put power steering fluid in there
guess I'll have to flush it out now
Just got off the phone w/ a nissan rep. and she says there's a recall on my vehicle. Then I called my local dealership and of course, no pick up
Left a message and hopefully they will call back. If you do call nissan at 1-800-NISSAN1(1-800-647-7261) they have it on file
Hope it works out for you. But I don't think it will do me any good since my vin falls out of that range. I just finished taking the PS fluid out and put some atf in. I'll have to drive around and let it circulate and then drain and fill again.
I got an apt a week from today. I hope this solves my power steering leak. I started taking some fluid out last night but I haven't driven the car yet so it hasn't circulated. I'll drain and fill again just like you
I use Mobil 1 synthetic atf...no leaks here.
Moble1 ATF will be perfect. I hope there is no damage to hte pump and other steering components. Drain and will 3 -5 times. That should be good.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
fastcarny
Oct 12, 2015 07:06 AM
