outside air
outside air
This isn't really for now, more for the summer. I'm wondering if there's a way on the auto climate control to allow the outside air to come in through the vents rather than using the a/c, or heat?
Your system always pulls outside air unless you press the recirculate button. Use ECON and set your system to the lowest temp setting and manually adjust the fan speed to bring in unconditioned air. You can direct it anywhere as well by using the MODE button.
When the system is off, air actually is flowing as you drive and it's tempered to meet the last saved temp setting when you turned off the system. You can actually change that by touching the cold or hot button with the system off! It will adjust the air discharge temp accordingly.
tarun900
19
Dec 20, 2021 06:57 PM
