Phillips blue vision/melted harnesses
Old Jan 22, 2004 | 03:08 PM
josh95se's Avatar
Has anyone else had problems with harnesses melting with these bulbs?
In the past 3 years I've used the bulbs...I've had the harnesses melt on me 6 times.
Old Jan 22, 2004 | 03:11 PM
Jepht20's Avatar
Custom User Title...
both harnesses or just one?
someone before mentioned checking your grounds. i had one melt on me but i had used noyka artic blues before and they melted them so i had to switch...hopefully they stop melting them, otherwise i'll just go back to stock or go hid's when i can afford them.
Old Jan 22, 2004 | 03:13 PM
MrEous's Avatar
^ Jeff™
This is just a guess but I bet it is due to the age of the harness. Make sure your grounds and all other wires are still connected properly.
Old Jan 22, 2004 | 03:16 PM
josh95se's Avatar
both harnesses go but at different times...you can see where the harness connects to the bulb that it's the slot on the right that always melts.
Old Jan 22, 2004 | 03:18 PM
josh95se's Avatar
Any specific grounds to check?
Old Jan 22, 2004 | 03:19 PM
felix's Avatar
Sittin' On Chrome
is it easy to replace the harnesses and where can i find some? thanks.
Old Jan 22, 2004 | 03:23 PM
josh95se's Avatar
You can get them from nissan or any parts place for 5-10 dollars. Just 3 wires to cut and reconnect.
Old Jan 22, 2004 | 03:29 PM
felix's Avatar
Sittin' On Chrome
does anyone make any heavy-duty ones?
Old Jan 22, 2004 | 03:38 PM
josh95se's Avatar
Where I've joined the new harness to the old wires...you can see that my connection was starting to melt there as well. (only on the one wire that melted at the harness) Would this indicate a ground problem? If so...where do I start looking?
Yes you can buy upgraded/better harnesses. I think apc sells them.
Old Jan 22, 2004 | 03:39 PM
mad-max98's Avatar
what's up ,,,,, save your time everybody the harn. will always melt . mine did 7 times with all kinds of bulbs just get rid of the problem cut the harness and use 3 terminal connectors this is the way to go it will never melt
Old Jan 22, 2004 | 03:47 PM
josh95se's Avatar
Were you using regular wattage bulbs? How long have you had it with just your terminal connecters?
Old Jan 22, 2004 | 06:58 PM
BigJayx23's Avatar
Hey wats up... u completely got rid of hte plastic piece that holds the bulb??? and just use 3 seperate connectors without using that plastic housing??? wat kind of terminals did u use???? have u had any problems since????
Old Jan 22, 2004 | 07:25 PM
bigleman's Avatar
Advocatus Diaboli
grounding doesnt work! i used 12 gauge on all connections and grounded directly to the factory grounding point right below the passenger side bulb and its still frying! i'll have to try the idea without the harness. somebody let me know if it works using the connectors
Old Jan 22, 2004 | 09:33 PM
BigJayx23's Avatar
so wats up? adding extra ground wont do jack? apparently the ground wire always burn... which totally sux.. anyone got a solution to this????
Old Jan 22, 2004 | 09:44 PM
ch13f's Avatar
Replacing the harness with another stock harness isn't going to help.. it'll just melt again. What you need to do is get an upgraded harness. I got a set from www.southwestautoworks.com and it's been fine ever since.
Old Jan 23, 2004 | 02:34 AM
mad-max98's Avatar
ok after melting my stock 5 times i got the one from ebay ' what a dumbass i was'' total waste of money still melted so i got rid of the harness completely cut the wires and put the terminal connectors then put them on the bulb piece of cake... sometimes the harness didn't last one trip 10 maybe 20 min. but i ve had my current setup for 3 months now no probs,,, you can get the terminal connectors from napa or k mart or anywhere and make sure theyre tight on the bulb terminals and then tape em up to isolate them ,,, i don't care who has bullitproof harnesses i'm not gonna waste my money or time trying to find out
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
