Thermostat Question ?? Cold Winter...
Old Jan 23, 2004 | 04:20 PM
matty's Avatar
Do thermostats get "tired" ??
128K miles on my max and I believe its the original thermostat...during the cold mornings (0-10 degrees here in NJ) it takes a little bit more time than it ususally does like say on a 30 degree morning to get heat threw the cabin. On a not so cold morning its not as bad. After I drive lets say 10 miles, the heat is cranking out of the vents. I was really wondering if i should replace the thermostat ?? Im just wondering if they get "tired" in a way ?
BTW i have the autp climate control
-matt
Old Jan 23, 2004 | 05:08 PM
G20Flyer's Avatar
Do you get to normal operating temp? If so, then urs is fine.
Old Jan 23, 2004 | 05:10 PM
matty's Avatar
yea mine is fine..I think its really just the really cold winter. Morning lows of -5 are really hard on the car when Im out there at 6:45 starting the car...I do let it warm up about 5 min so Ill have to go 10 from now on..This is the coldest winter so far since I owned the max
-matt
Old Jan 23, 2004 | 05:11 PM
mansurxk's Avatar
-matt
as to my knowledge, which is problaby very little, thermostats do get tired, they eventually may get stuck in open closed or some halfway position could be disasterous depending on what position it fails in (if you continue to drive) doesnt hurt to change it, i havnet done it in my maxima yet (i just bough it a few months ago) but if it takes a while for the car to warm up, its probably stuck in the open position (thats waht the haynes manual says)
Old Jan 24, 2004 | 11:11 PM
(_8*(l)Homer's Avatar
Lows of -5. Try lows of -30 here. The Max still starts up fine, heat does take longer depending on outside ambient temperature.
pears
Sep 18, 2015 05:25 AM
97_GXE
20
Sep 17, 2015 08:12 PM
aminus21
Sep 12, 2015 04:53 PM
