Cleaned TB, now car won't start
I'm not sure why my car won't start after I cleaned the throttle body. I put everything back together that I took apart. The only thing I can think of is that I may sprayed some carb cleaner behind the throttle plate...did I mess up?
Other than that, some carb cleaner may have landed on the starter but this shouldn't be an issue. I've only owned this car one month and it has had trouble starting the first crank every so often...which could be the starter. by the way, the engine cranks... just doesn't turn over. Is this purely coincidential or did I do something wrong? Thanks to anyone with insights.
VIC
VIC
VIC
VIC
Originally Posted by myke321
Do alot of people have problems after cleaning the TB usually? I was gonna do this, but i hear alot about high idle Rpms and stuff.
well im posting this for the 5 time already lol, but i cleaned my throttle body also this weekend, and i actualy tok off my throttle body and i took off the plate also so i did a preaty good deep clean but i didn't have any problems after that i just had to adjust the throttle cables and it worked fine. maybe u didnt plug something up right. that is the onely thing i can think off, i think there are like 3 plugs that connect to the throttle body including the mass airflow sensor. im preaty sure it could be one of ur vacume or air hoses are disconected or they are not connected right, there is one hose that goes from the bottom of ur throttle body to the top and there are 2 coolant hoses towords the bottom and maybe 1 or 2 more that i can't remember.
When I cleaned my throttle body last month, I got too much cleaner inside and it fouled out the plugs. It started, then died. I replaced the plugs and it started right up. Make sure if you ever replace plugs, use NGK laser platinums or v power coppers.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
BobMax
Aug 15, 2015 12:35 PM
