Cylinder misfire code - help!
Old Jan 26, 2004 | 10:22 AM
Neif's Avatar
Well I got the ECU codes from my computer after my SES light came on. It gave me two codes, 0304 - bad knock sensor, and 0608 - Cylinder 1 misfire. I'm hoping it's not my fuel injectors that are bad, as I'm too broke to replace em. I heard from another forum that if you get the knock sensor code and the misfire code together then it's usually the coilpack over the sparkplug that went bad - has anyone heard of this?
Would anyone know how I could take off and swap out the coilpacks?
Old Jan 26, 2004 | 10:49 AM
NmexMAX's Avatar
dot dot dot ...
Decode the ECU to find which cyl is misfiring, than change the blamed coilpack with another and if it continues missing(running the same, than it's a coil pack. 77 dollars.
Old Jan 26, 2004 | 10:50 AM
fisher01's Avatar
Just switch coil pack to cylinder 3. Reset ecu, drive around. If new code comes up showing cylinder 3 misfire, then you know coil pack is bad.
Old Jan 26, 2004 | 11:58 AM
Neif's Avatar
how do I switch the coil pack? And yeah I already decoded the ECU and it's cylinder 1
Old Jan 26, 2004 | 02:39 PM
fisher01's Avatar
Each coil pack is held in place by 2 screws. First remove wire harness connector by pushing upper tab. The connector will slide out. Then remove screws, pull coil pack upward. Switch coil packs to next cylinder which would be number 3. Reset ecu, drive around. If your coil pack is bad, you should get a misfire code for cylinder number 3 now.
Old Jan 26, 2004 | 05:11 PM
Kevlo911's Avatar
Kevlo for President
0603 0604 0605 0606 0607 0608
If one cylinder is misfiring the problem is spark or fuel. A misfire due to a spark problem usually results in a Service Engine Soon light and one of these Diagnostic Trouble Codes:
0607 - Cylinder 2 misfire
0606 - Cylinder 3 misfire
0605 - Cylinder 4 misfire
0604 - Cylinder 5 misfire
0603 - Cylinder 6 misfire
There are two tests the home mechanic can make, the sound test and the resistance test.
Sound test...
This test is performed with the engine idling. Use a mechanic's
stethoscope or a length of rubber vacuum hose, and listen to each injector.
All injectors should sound alike. If you find one which makes a different
sound (or no sound at all) you have found a problem.
Resistance test...
This test is performed with the engine off. Use an ohmmeter to measure the
resistance of each injector. This does not require removing the injectors.
I don't know the correct resistance value for the injectors on your model,
but they are typically a low number such as 16 ohms. The important thing
is they should all be equal. If you find one injector with substantially
higher resistance than the others, it is bad. If you find one with zero
ohms (short circuit) that is truly unfortunate, because the injector is bad
and it may also have damaged the Engine Control Module (the computer)
because of excessive current drain.
Measuring the resistance of the front bank of cylinders is easy because the
injectors are in plain view. Disconnect the injector electrical connector
for cylinder #2, measure the resistance, reconnect the connector. Repeat
for the cylinders #4 and #6.
Measuring the resistance of the rear bank of cylinders is almost as easy,
but it is difficult to reach the injectors. The resistance may be measured
at a conveniently located electrical connector. Notice the largest,
thickest electrical harness at the top of the engine. This is the Engine
Control Harness and it is shaped like a U, with the open top of the U at the
driver's side of the car. The U has two corners. Look at the corner
nearest the passenger seat. Just inside that corner you will find an 8-pin
electrical connector. This is connector F131. Disconnect this
connector. Now look at the male part, the connector half with the pins
exposed. They are arranged in two rows of four pins.
The pins are numbered 1 - 4 (top row) and 5 - 8 (bottom row).
Measure the resistance of:
- injector #1 between pins 1 and 2.
- injector #3 between pins 1 and 6.
- injector #5 between pins 1 and 5.
Be sure to measure the PINS, not the female receptacles.
The dealer's shop is equipped with high-tech diagnostic instruments. These are wonderful devices but they are expensive and the dealer has to recover his cost by charging you for diagnostic time. Sometimes the home mechanic can do legitimate diagnostic work with nothing more than a ohmmeter and a rubber tube.
To Test Ignition Coils:
With the ignition off, disconnect the electrical connector from the ignition coil. Connect the positive (+) probe of an ohmmeter to terminal no. 1 and the negative (-) probe to terminal no. 2 of the coil connector - the meter should indicate infinite resistance. Reverse the meter leads ( negative probe to terminal no. 1 and positive probe to terminal no.2) - the continuity should be indicated, but not zero ohms. If the results are not as specified, replace the coil.
Connect an ohmmeter between the secondary terminal ( the one that the spark plug connects to) and terminal no. 1 - the meter should indicate infinite resistance. If not, replace the coil.
jmlee44
Oct 2, 2022 02:13 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
