about the MEVI
Old Jan 26, 2004 | 04:18 PM
MaxGR97's Avatar
about the MEVI
Im looking into maybe getting one of these, but i dont know hardly anything about them. Im kind of sure on how theyre used, but not positive, so could someone try to explain to me how it works? Also on the webpage to buy it ( http://www.courtesyparts.com/Merchan...duct_Code=MEVI ) it says that i still need to buy other parts to install it, how do i know what parts i still need to get? and on http://maxmods.dyndns.org/index.php?...ariableIntakes it says i need an "RPM switch" , how does this work?
Old Jan 26, 2004 | 04:25 PM
ABK's Avatar
ABK
that's like 3rd question like that for a week.
MEVI has two intake runners one is longer and other is shorter. When you hit certain RPMs, rpm switch opens up the secondary runners on MEVI and gives you more power.
Old Jan 26, 2004 | 04:28 PM
CullenJ76's Avatar
no, it does not have two sets of actual runners.
Old Jan 26, 2004 | 04:30 PM
MaxGR97's Avatar
OHhhh when they said switch i thought they ment like toggle switch that id have to switch after EVERY shift. So it has a long and a short runners, but how exactly does this give more power?
Old Jan 26, 2004 | 04:31 PM
MaxGR97's Avatar
wait wait i THINK i get it now...so on low RPMs its like normal intake manifold, but when you hit higher RPMs the the other set of runners opens up for more intake flow????
Old Jan 26, 2004 | 04:39 PM
nismology's Avatar
It is basically the same design as the stock intake manifold except is has a resonance chamber built into it. If you are familiar with the concept of dynamic supercharging it utilizes this to produce power in higher RPM. One thing to note however, is it is not resonance tuned like the USIM in the midrange 3K to around 5.5K RPM and your mid-range torque will take a hit, but you will have higher torque production after 5.5k RPM.
The car will not pull any harder (it actually produces less peak torque) but it will pull for LONGER in the rev-range if that makes any sense.
Old Jan 26, 2004 | 04:40 PM
CullenJ76's Avatar
PLEASE read this:
http://forums.maxima.org/showthread.php?t=217001
MEVI FAQ
Old Jan 26, 2004 | 04:43 PM
JeremyMarkham's Avatar
I have one sitting in my garage...I have yet to install it. If I go for the Bimmer I may sell it.
litch
123
Jan 4, 2024 07:01 PM
maxprivate
Nov 29, 2017 08:52 AM
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
BkGreen97
Apr 2, 2016 05:47 AM
lrb6805
Sep 30, 2015 08:12 AM
