Swapping ECU'S
Old Jan 27, 2004 | 11:42 AM
96white's Avatar
Swapping ECU'S
I was wondering if some memeber who have swapped ecu's could give me an idea how to. What should i do. Should i dissconnect the negitive battery cable etc ...
thanks !
Old Jan 28, 2004 | 05:12 AM
96white's Avatar
no one knows how to take out the ecu?
Old Jan 28, 2004 | 06:10 AM
Stephen Max's Avatar
thanks !
Yes, it's always a good idea to disconnect the battery first. Pop off the plastic cover over the harness connector, then use a 10mm socket to remove the harness connector from the ecu. After that it's a matter of getting in there and removing the two Phillips head screws at the front and the two in the back that hold the ecu to the mounting frame. It's a b!tch the first time because of limited access space for the back two. When you reinstall the ecu, don't worry about putting those two back in.
Old Jan 28, 2004 | 06:53 AM
Ceasars Chariot's Avatar
Old Maxima Legend
i switch my ecu's all the time. is disconnecting the battery necessary ? i never do that ?
Old Jan 28, 2004 | 07:34 AM
ZuMBLe's Avatar
Get a rachetting angled phillips head screw driver. It will make life a lot easier. I think I paid 9 dollars for mine and it was worth every penny!
Old Jan 28, 2004 | 08:39 AM
It's not absolutely necessary, but it's always a good idea to disconnect the battery before working on electrical components. Could save you from accidentally shorting a circuit.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
gigabyte
Jan 6, 2017 06:05 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
