Technosquare ECU Upgrade
Hey guys I was wondering where I could get the Technosquare ECU Upgrade from.. And how does it work... Do they just send out the chip or do I send in the whole ECU... Also when you put the ecu back in the MAX should it be ready to run.. I dont want to screw my car up with the Technosquare ECU Upgrade. I want it to still run good. I just dont want to have to do a lot of tunnning in and stuff i guess. Thanks Rich
2. You send in your entire ECU (Warning-- If you have a 99 Max, you will be without your car 3-5 days unless you buy a brand new ECU to replace your NVIS equipped ECU for that time period AND get keys programmed...)
3. The Max wont just run when you replace the ECU... it roars. Performance and featureset should be on par with the JWT ECU 9only they don't make one for the 99 Max...)
4. No tuning required. A caveat, however. Should you become boosted (i.e., Supercharged, turbocharged, or nitrous, you will need the ECU re-programmed, (timing and fuel map adjustments must be made...)
Thanks man
Thanks for your input... Dang 600 bones.. More than I was expecting, you all think its really worth it.... So i have a 97 I know about the whole check engine light thing I just still purchase what is called the 95-96. Thanks guys Later
1. yeah
2. yeah, and no they don't have ECUs yet made for 98-99 maxes, and you will be without your car for 5 days anyways.
3. JWT and Technosquare are not the same, JWT is better for mevi applications because of the extended redline. People without MEVI prefer Techno.
4. Unlike JWT, Technosquare doesn't tune the computer for you specifications, I think.
Originally Posted by ABK
1. yeah
I've spoken with Danny Lee of Technosquare, who states that the fuel ratio and timing map are optimized (according to whatever mods you specify unless you can bring the car in), any speed limiters are removed, and the redline is extended.
As far as i can tell, that's the full extent of the JWT ECU upgrade as well. Correct me if i'm wrong.
i dont think they program the 98-99. if you have a 97 like me then you have to buy a 96 or 95 ecu and send it to them. IMO it is much easier to buy a new ECU for 80 bucks or so and keep your old one and send the new one in to be reprogrammed. this way you don't have to let your car sit for 3 or 4 days and you can check your CEL codes if they do appear. also look in the group deal section. i believe there is still a deal going on. i will most likely be selling my technosquare ECU in the summer if you can wait that long. but i am still not sure yet
Ceasar congrats on max of the month
And they were working on taking off the rev limiters I think.
1. www.technosquareinc.com
Originally Posted by ImStockBaby
What is NVIS anyways?
