Painting Dash
Old Feb 10, 2004 | 06:38 PM
hollaatchaboi's Avatar
Painting Dash
I'm in the middle of painting my dash. I'm follwing the directions off of vqpower.com and everything is coming out great, however, I have a GXE with manual climate contol. Does anyone know of a way to paint this? Is there a way to take the face off so that I can paint it? Anyone have any tricks? Please let me know, thanx.
Old Feb 10, 2004 | 07:00 PM
d_warner's Avatar
Old Timer
That is actually my write up. I have manual controls myself. The only way to paint that, is to tape off what you dont want painted, and then spray it. I didn't want to run the risk, and left it black.
Old Feb 10, 2004 | 07:37 PM
Just want to compliment you on your dash and the write-up. So there is no way of taking the face off?
Old Feb 10, 2004 | 08:20 PM
Can anyone with custom painted dashes post their pics?
Old Feb 11, 2004 | 04:39 AM
bump......
Old Feb 11, 2004 | 10:02 AM
Show Maxima's Avatar
im interested too, please send pics of painted dashboard, and interior peices.
Old Feb 11, 2004 | 03:30 PM
wariow's Avatar
yes you can take off the face to paint. I just changed the led's for my manual climate control. Just take it out of the car just as you would when you remove the stereo.
remove the back piece, there's two circuit boards over each other. to remove the top piece you would have to use pliers to squeeze the plastic pieces that is holding the top board to the bottom board and pull the board while squeezing the plastic pieces, there are two of them I believe. Once you got that out. You can remove the turn **** that controls the fan speed in the front. pull out the **** from the front or use a small screw driver to wedge it out. While you're doing that take off the buttons for the fan directions also. (face, face + ground, ground only, etc.)
After you remove the turn **** and the buttons go back and try to remove the turn **** mechanism from the back. There might be a screw on it but I'm not sure, remove if you see one. On the side of the whole unit there are wedges to secure the boards and the turn **** piece in place. use a small screwdriver to stick it in and "unlock" the piece and pull the turn **** thingy out. Do it for any other wedges that might be holding the turn **** thingy in place.
after you get the turn **** thingy out you can pull out the other board. Remove the two screws on each side and if you look on the side again, there will be wedges securing the circuit board also, repeat the same procedure and it should come out eventually. It's a lot easier if the front fan direction pieces are out already.
After taking the board out there's another board on the bottom for the temperature slider. Pull out the sliding bar in the front. There's another wedge to hold the circuit board so repeat like before. Take out the plastic/glass pieces. After that, all the electronic parts should be out and ready for paint.
If you have any questions shoot me a PM or IM. Hope it helped.
Old Feb 11, 2004 | 04:11 PM
WOWW!!! thanx for the info. This sounds too complicated and knowing me, i'll break an important piece. I think i'll just tape it up and be very careful. Thanx
Old Feb 11, 2004 | 04:18 PM
Oblongshapes's Avatar
go to my webpage, and click on interior for pics
REDinLV
Aug 15, 2024 12:30 AM
Apr 16, 2020 05:15 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
