tranny removal question
Old Feb 10, 2004 | 06:50 PM
mymaxlvsattn's Avatar
slackass
hey quick question...what is the easiest way to remove the clutch slave cylinder from the top of the transmission? 1. Im not 100% sure im looking at the right piece 2. if this is right..how the HECK does one get to the back bolt?
the Haynes manual speaks of disconnecting the hose from the banjo....yeah i have no idea
any help would be appreciated
Old Feb 10, 2004 | 10:55 PM
sryth's Avatar
Don't disconnect the hose from the slave cylinder...that will require you to bleed the clutch system (unnecessary). Just remove the two bolts, and hang the cylinder out of the way (don't use the hose to hang it...put a zip-tie through one of the bolt-holes)
As for identifying this thing: The slave cylinder has two bolts on the bottom of it that fasten it to the tranny itself. It has a banjo connection to a hose that eventually leads to the clutch master-cylinder. It pushes against a lever that goes into the transmission. Oh yeah, it's the only thing on the tranny with a hose going to it.
The search isn't working (weird error), so this is the best I could dig up (photo-wise). There are a few decent shots of the slave cylinder.
http://www.motorvate.ca/mvp.php/802
In order to get to that bolt, just find a wrench/socket that you can squeeze in there. If you're having trouble here, wait until you get under the car There's one bolt (through the shift-rod support bracket) that would drive a minister to drink.
Old Feb 11, 2004 | 01:21 PM
slackass
hey thanks for your help
The Frye
Sep 2, 2021 11:03 AM
pktaske
May 6, 2016 07:49 AM
Colossus
Sep 9, 2015 05:46 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
