New Ecu Install help!
Old Feb 11, 2004 | 02:31 PM
burrll_gee's Avatar
I got a "new" rebuilt ecu from nissan, and i want to install soon.
What is required (IE disconnect battery) Anything else
BG
Old Feb 12, 2004 | 07:24 AM
burrll_gee's Avatar
bump - no one ? Come on i know someone has swapped an ECU before ! help me please
Old Feb 12, 2004 | 07:42 AM
plurco's Avatar
dissconnect the - battery terimnal, install new ECU then reconnect battery.
Old Feb 12, 2004 | 07:48 AM
amb4081's Avatar
I just pulled my ECU out last week and sent it off for a flash upgrade. The ECU is not fun to take out. First, disconnect the battery. Let it sit for around ten minutes before proceeding to disconnect the ECU. Disconnecting it disables the airbag system. From there, remove the bottom kick panels on the center console, exposing the ECU and harness plug on the passenger side. Remove the bolt holding the harness plug-in. Then remove the 4 phillips screws (2 facing front and 2 facing rear) holding the ECU in the bracket. Then, slowly and carefully slide the ECU out.
Old Feb 12, 2004 | 08:26 AM
burrll_gee's Avatar
thanks much, its seems simple enough looking at the new one, any estimate of time? i think i will do it after work if its not too cold or dark.
Thanks again !
Old Feb 12, 2004 | 09:05 AM
I30tMikeD's Avatar
It is not that hard to remove the ECU but it is a PITA to put the new one in. There is no room at all to work with down there. I still don't have mine correctly mounted.
I never disconnected my battery when replacing mine.
Old Feb 13, 2004 | 05:09 PM
96white's Avatar
I hate to disagree but i just removed mine last night, and the hardest part is getting the back screws. the re-install is easy IMO.
QueensMAX
Sep 15, 2015 04:14 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
