maxima jerking
Old Feb 14, 2004 | 10:52 AM
luga982's Avatar
maxima jerking
hey guys,
i drive my maxima in new orleans, and i noticed that at red lights, my rpm guage fluctuates between 1 and 0 vigorously. coupled with that, my car jerks before it takes off. it sounds like a cylinder misfire, and i don't know what to do.
has anyone ever had that problem? how did you fix it? also, if you know about it, please be kind enough to walk me through what i should do step by step.
peace
Old Feb 14, 2004 | 11:17 AM
All*Pro's Avatar
Tell it to stop doing that or it will go blind
But seriously.....it can be a number of things: fuel related(injectors, clogged/dirty filter, bad fuel from the last time you filled up etc.), iginition related(check your ign. coils), bad spark plug(s), oxygen sensor etc.
When is the last time you had a tune-up done? If its been a long time since you can remember....start with that. Good luck.
Old Feb 14, 2004 | 02:18 PM
luga982's Avatar
hey man,
i remember fueling it with 87, instead of 93 octane gas, and i changed the head gasket for the coils a while ago. could it he messed up again?
also, if it was the coils that were bad, shouldn't there be a misfire code? cuz i don't see anyc codes showing a misfire."
thanks in advance
Old Feb 14, 2004 | 07:35 PM
2 Da Max's Avatar
If i was you i would clean da throttle body with some throttle body cleaner to get rid of da dirt, and dat should fix da rpm.
Old Feb 14, 2004 | 08:03 PM
Jatan's Avatar
Clean the TB and put in 93 octane gas when the tank in near empty. If the coil packs are dying and not completely dead, they will not throw a CEL. They only throw a CEL when they're completely dead.
When was your last tuneup? Use NGK spark plugs, change the air & fuel filter, change the PCV valve, and you can try some Sea Foam (http://forums.maxima.org/showthread.php?t=284423)
kingw323
20
Oct 21, 2015 08:36 AM
Goffery2uned
Aug 21, 2015 09:50 PM
maxima297
Aug 3, 2015 12:50 PM
