Summit RPM Switch
Old Feb 16, 2004 | 10:56 AM
kitmaxima's Avatar
Summit RPM Switch
i have installed the MEVI
vacuum works fine
soleniod works fine
i need help on the electrical part
i have tried all the diagrams on the MEVI infos
i got it working but the thing is
its always on
my wirings are:
red--------- batt
black------- ground
white------- comp (green and white wire in the comp)
yellow and grey are on the soleniod
i ran the can to test the rpm switch
rev it up to 5000rpm no response on the MEVI
setting of summit switch is 2200rpm
no relay on this set up
when i put the relay it is always on
can someone help me with the wirings
Old Feb 16, 2004 | 11:04 AM
98SEBlackMax's Avatar
Maxima.org Insomniac
vacuum works fine
soleniod works fine
its always on
my wirings are:
red--------- batt
black------- ground
Ok well the Tach signal wire is a white wire with a green stripe coming from the ECU. And IIRC you dont need both wires from the Summit switch attached to the solenoid, just one. One wire is normally open (open circuit until Summit switch reaches target RPM, then closes) and the other is normally closed (Closed circuit until Summit switch reaches target RPM, then opens) you want to use the wire that is normally open so that it activates the solenoid only when the engine reaches the target RPM setting.
Old Feb 16, 2004 | 11:05 AM
I30tMikeD's Avatar
There should be one wire unused with the summit switch (I think it's the grey one). There is two activation wires, one is an on and one is an off. You will have one going to the battery (or whatever power source), one going to the ground, one going to the ECU, one to the soleniod, and one is not used.
Once you have the wiring correct and if you still have problems try setting the summit switch for a different rpm....seems some have to use different settings for a 5kish activation. I have to use 3400.
**edit** yes it is the grey one that is unused**edit**
Old Feb 16, 2004 | 11:16 AM
kitmaxima's Avatar
thank you i go and try it
Old Feb 16, 2004 | 12:54 PM
kitmaxima's Avatar
i tried it
nothing happened
any other ideas
Old Feb 16, 2004 | 12:59 PM
kitmaxima's Avatar
also then i have to ask you guys
the other soleniod wire is ground right
Old Feb 16, 2004 | 05:35 PM
No, one solenoid wire should be +12V and the other should be the yellow summit switch wire. When the target RPMs is reached the yellow wire becomes a virtual ground allowing the solenoid to activate.
Old Feb 16, 2004 | 06:10 PM
hotshtsr20's Avatar
anyone dyno'd the MEVI yet?
you guys getting them from junkyards, or new from nissan? new sounds expensive.
Old Feb 17, 2004 | 01:18 PM
kitmaxima's Avatar
thank you again
i will try it
Old Feb 17, 2004 | 01:26 PM
kitmaxima's Avatar
i got mine new
i have dyno my car period
i need a few more upgrades
i will dyno when all upgrades are all on
so it be tune too
not just base run
but if you are looking for a MEVI dyno
i believe they all in here
if you can search
i can not tell you right now
it bookmark on my other comp
sorry about that
Old Feb 17, 2004 | 01:37 PM
bignick's Avatar
i got mine new
so it be tune too
not just base run
if you can search
sorry about that
Maxima.org heiko?
Old Feb 17, 2004 | 10:44 PM
Spaniard's Avatar
Originally Posted by bignick
Maxima.org heiko?
lol my thoughts also!
My max is so fast
It turns around turns
when I push my right foot down
away go the things
Old Feb 18, 2004 | 11:37 AM
hotshtsr20's Avatar
cant search. not a "registered user" and i cannot donate to become one.
can anyone do a search? i would be greatly appreciative. thanks!
Old Feb 18, 2004 | 11:39 AM
kitmaxima's Avatar
My max is so fast
away go the things
hey
car should go forward
not around
just a pointer
goodluck
Old Feb 18, 2004 | 11:49 AM
kitmaxima's Avatar
here you go
http://forums.maxima.org/showthread.php?t=217001
that is the mevi info
enjoy
gavin68
Sep 18, 2021 12:36 PM
Need help
23
Oct 2, 2015 08:56 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
