Cutting a coil on eibach
Old Feb 19, 2004 | 06:39 AM
Daze4u2nv's Avatar
if i cut a coil on a set of eibach springs cause i want a bit more of a drop, will it affect the way the eibach make the car handle or would it just drop it more with the same handling characteristics. im thinkin like when people cut the "dead coil" on the rear sprints in order to make it sit even.
Old Feb 19, 2004 | 10:30 AM
Max Noob's Avatar
everyone is gonna tell yuo dont do it..
i have my maxspeed springs cut 1 coil all around. ride got a little bit stiffer, nothing i cant live with. handling is still fine. much better than stock. i only drove with the maxspeed at full height for a week..so i dont know which handling setup is better.
eibach is a much stiffer spring than maxspeed though. so you may get worse results than me.
if you dont mind the stiffness, it shouldnt be too bad. the major concern with cutting springs is bottoming out often. eibachs dont lower much to begin with.
fronts dont have a dead coil to cut... that is where there is a problem. it wont sit perfectly on the spring seat after the cut. if you happen to drive off ramp and your car looses touch with the ground. the spring may unseat itself. causing alot of problems for you.
up to you.. but if you have eibachs(pretty pricey).. im sure u can sell them on FS forum, buy sprint(pretty cheap) springs have still have 20-50 bucks left over to buy new strut bearings. IMO.
Old Feb 19, 2004 | 10:38 AM
ABK's Avatar
ABK
if you cut the springs you make them sit little messed up, I would think it would be unsafe, and I think by doing this you basicly ruin your springs.
Old Feb 19, 2004 | 11:49 AM
ohannon7's Avatar
sell them, buy lower springs.....
Old Feb 19, 2004 | 03:33 PM
Daze4u2nv's Avatar
yea but wouldnt sprints cause premature wear on the cv joints or w/e
Old Feb 19, 2004 | 03:36 PM
ohannon7's Avatar
I love my progress springs......
Old Feb 19, 2004 | 03:38 PM
Daze4u2nv's Avatar
ohannon u have pics of your car on progress? and how does it handle?
Old Feb 19, 2004 | 03:54 PM
I30tMikeD's Avatar
Eibach's are progressive rate springs and cutting them will change the way they work
Old Feb 19, 2004 | 04:27 PM
Daze4u2nv's Avatar
guess ill go with sprints and just wait and see how long the cv joints will last me
Old Feb 19, 2004 | 04:39 PM
michaelnyden's Avatar
exactly....don't cut eibach springs...that will mess up the progressivity of the springs which is the entire point of them in the first place....it would be less terrible if it were a "linear rate" spring
Old Feb 19, 2004 | 05:17 PM
1FSTMAX's Avatar
I thought Eibachs are a linear spring....
Old Feb 19, 2004 | 05:35 PM
ohannon7's Avatar
I thought it was too? progress is a progressive spring. Im pretty sure you can tell by looking at them. Progressive ones go from a bigger to a smaller, tighter spiral. linear ones dont. Correct us if were wrong, I know theres suspension pros out there......
Old Feb 19, 2004 | 06:04 PM
I30tMikeD's Avatar
No, they are progressive.
Old Feb 19, 2004 | 06:14 PM
ohannon7's Avatar
Sorry this is the best pic I have right now, BTW-this is not how my car looks anymore, the rims and grill is gone, Ill try to put up pics tomorrow. Im very very happy w/ how they handle.
Old Feb 19, 2004 | 06:49 PM
RastaManMax's Avatar
All lowering springs to my knowledge are progressive. Coilovers are linear.
LEMAR
Old Feb 19, 2004 | 07:08 PM
ohannon7's Avatar
read up <---clicky
10 chars
Old Feb 19, 2004 | 09:39 PM
Daze4u2nv's Avatar
but damn i love those sprint drops...1fstmax drop is insane. but im just worried about the cv joints wear and if it will handle good with that setup
Old Feb 19, 2004 | 09:47 PM
1FSTMAX's Avatar
Almost two years and no problems so far. I belive that the CV joints only wear out on auto's.
Old Feb 21, 2004 | 11:19 AM
Daze4u2nv's Avatar
yea but what about with good alignment job done
TallTom
57
Oct 14, 2025 05:16 PM
magiconthetire
Oct 26, 2015 09:03 PM
RealityCheck
Oct 2, 2015 06:34 PM
zmcneely13
Sep 26, 2015 02:26 PM
