Sqeeking clutch cable
Old Mar 11, 2001 | 10:27 AM
MacGyver's Avatar
I had the car off and the hood open. I pressed the clutch and i hear a sqeeking noise. I asked a freind of mine and he said it is most like the clutch cable. he said i could get it adjusted if i wanted, but it nothing to worry about. Anyone else have this problem and is this something minor i should forget about?
Old Mar 12, 2001 | 04:53 AM
Daniel B. Martin's Avatar
Your friend is misinformed. 4Gen Maximas have a hydraulic clutch actuator. You car doesn't have a clutch cable.
Old Mar 12, 2001 | 09:49 AM
2ndMAX's Avatar
Check the release bearing/throw-out bearing....
Same thing used to happen to my 96 Max. Its sometimes referred to as a "throw-out bearing" or "release bearing". And if you're gonna have a shop do the work have them inspect your clutch lining and other transmission internals, since they have to take apart the tranny to get to the deffective part.
Old Mar 12, 2001 | 10:07 AM
Clutch release bearing
A bad clutch release bearing (a/k/a throwout bearing) will emit a shrill sound when you foot is on the clutch, including when the clutch pedal is "floored". It will be heard even when the vehicle is not moving.
If you must replace the clutch release bearing, you might as well install a new clutch at the same time. Labor makes up the largest part of the total bill and it would be a shame to pay it all over again 20K or 30K miles later.
... if you're gonna have a shop do the work have them inspect your clutch lining and other transmission internals, since they have to take apart the tranny to get to the deffective part.
This is not correct. The transaxle must be removed from the vehicle to replace the clutch release bearing. However the transaxle does not have to be taken apart. The technician does not have an opportunity to inspect the transmission internals in the course of a clutch job.
Old Mar 12, 2001 | 11:07 AM
sinewave's Avatar
The throw-out bearing usually only makes noise when the engine is running. Try oiling the clutch pedal pivot point.
Old Mar 12, 2001 | 11:23 AM
Originally posted by sinewave
The throw-out bearing usually only makes noise when the engine is running. ...
You are right. MacGyver said "I had the car off ..." and I didn't understand he meant "I had the engine off ..." The squeak cannot be the clutch release bearing. The release bearing turns
- at zero rpm when the clutch pedal is fully released.
- at engine rpm when the clutch pedal is pressed more than the 3/4" free play.
When the engine is not running, the release bearing is not turning... and therefore not making noise.
Old Mar 12, 2001 | 12:46 PM
NickStam's Avatar
So if the car is off and there is a small squeak when the clutch is depressed, then what might need to be greased?
Old Mar 12, 2001 | 12:57 PM
Use the vacuum-hose listening aid to identify the source of the squeak, and lubricate that spot. Possibilities include the pedal pivot point under the dash, the tip of the clutch slave cylinder pushrod, and the clutch lever pivot ball.
Old Mar 12, 2001 | 02:08 PM
MaxRX7
look below
user 11122324
42
Jul 18, 2022 03:35 PM
gigabyte
Jan 6, 2017 06:05 PM
sliptap
Sep 30, 2015 05:57 AM
pktaske
Sep 4, 2015 08:40 AM
