Stock Alarm System Question.
Old Feb 19, 2004 | 03:44 PM
Cal0205's Avatar
Stock Alarm System Problem!
Every since i got the car the alarm system never done this.
10 mins ago i was down stairs setting up a pair of Neon Lights under the Dashboard.
I turn on the car to test out the lights and it worked great. While the key was in the car, i opened my door and suddenly the alarm system went off.
Next--I close all the doors, lock the doors and opened the trunk with the wireless key and the alarm goes off.
When I unlock the doors. all the Lights goes on--break lights, ALL the interior lights, side eye lids and the gauages.
Now when i lock and unlock the doors it makes a beeping sound....never heard that before.
Did I do something wrong with the alarm system?
Old Feb 19, 2004 | 03:46 PM
nismos14's Avatar
§è~® f®ÈÄk
how did u wire up ur neons?? that might have something to do with it
Old Feb 19, 2004 | 03:48 PM
Cal0205's Avatar
Cigar Lighter.....I did tie wrap it around a small wire under the driver's seat....one black single wire that goes out into a small hole.
Old Feb 19, 2004 | 04:00 PM
nismos14's Avatar
§è~® f®ÈÄk
take the zip tie off the black wire and check for any rip in the wire, that might be it, otherwise im stumped
Old Feb 19, 2004 | 05:50 PM
Cal0205's Avatar
there;s no damanage to the wire.
Old Feb 19, 2004 | 05:53 PM
bobjohnson's Avatar
Blazin......
Reverse whatever you did. then try to wire from under the hood if i were you.
Nissan was very cheap w/ the wiring on our cars so you may have scrapped a wire somewhere along the lines..
Old Feb 19, 2004 | 06:06 PM
Maximum96's Avatar
one day i closed my trunk REALY hard and ever since then i have an alarm system, 3 yrs with the car and last month i found out i had an alarm system, i have no idea what happened!
Old Feb 19, 2004 | 06:26 PM
Cal0205's Avatar
I know exactly what you mean. Had the car for over a month and the Alarm never goes off unless i press the panic button.
I think i bang my head on the alarm light before and now the system is so sensitive.
Old Feb 19, 2004 | 06:28 PM
sadice's Avatar
alarm is always there when u turn it on u got to wait for a min or so and than it works...... for example sit inside lock the doors wait for a minute or a little longer and than open the door manually and the alarm will sound.....
Old Feb 19, 2004 | 06:30 PM
Cal0205's Avatar
is there an alarm sensitivity setting somewhere?
Old Feb 19, 2004 | 06:33 PM
sadice's Avatar
no not that i know of ask in audio section maybe they know......
Cal0205's Avatar
But it never use to do that.....I use my remote to open the trunk and it goes off.
I unlock all the doors, all the Light comes on, the guages, interior lights, break lights, and fron turn and eye lids.
Old Feb 19, 2004 | 06:36 PM
sadice's Avatar
damn u deff did mess up the wiring heh.. go ask this question in the audio section there u should get more info than here try it....
Old Feb 19, 2004 | 07:25 PM
Cal0205's Avatar
Where is the alarm system located? Flipped thru the manual, says nothing about it.
Old Feb 20, 2004 | 10:08 AM
Cal0205's Avatar
anyone else have an idea on this?
Old Feb 20, 2004 | 07:16 PM
Cal0205's Avatar
Oh btw, this car has an anti theft system. Is there a sensitivity setting somewhere?
I dont want to waste money taking it in so they can just push a button and fix things.
Old Feb 20, 2004 | 07:36 PM
sadice's Avatar
there could be one if some1 modified it go to www.vqpower.com and click How To's DIY's and look for glass and shock add on for the stock alarm u'll c it read on it tells u where it is so check that out maybe thats it??? ...... good luck
9aj9
Apr 5, 2020 12:11 AM
BkGreen97
Apr 2, 2016 05:47 AM
kjlouis
Sep 14, 2015 11:22 AM
220k+ A32
Sep 11, 2015 02:18 AM
TheMafia
Sep 4, 2015 08:26 AM
