Putting 2 DE-K exhaust cams in a DE.. opinions?..
Old Feb 20, 2004 | 02:59 PM
phatmax95's Avatar
There are some KA people out there who have done it and showed gains.. two exhaust cams, (swap the intake cam with an exhaust cam). I wonder if using two DE-K cams since they have bigger lobes on a DE would give any gains?
Old Feb 20, 2004 | 04:38 PM
nismology's Avatar
The only advantage the DE-K cams possess is the exhaust lobes are ever so slightly larger. The intake cams on both engines are identical. Plus both the intake and exhaust valves have more duration in the DE and have more overlap. This has been discussed already and the general consensus is that the MAIN power difference between the 2 engines is the DE-K VI. Without it, you will be disappointed.
In other words, not worth it.
Old Feb 20, 2004 | 06:21 PM
NickStam's Avatar
slap em on and let us know
Old Feb 20, 2004 | 10:42 PM
phatmax95's Avatar
I know all that. The exhaust cams have more lobe. So replacing the intake cam and exhaust came on my DE with a two exhaust cams from a DE-K. I really don't think this has been discussed if it has I must have missed it.
I did a cam swap on a KA tonight it was pretty easy it only took us about 2 hrs and not ever having done it before.. Just wondering if anyone has any good feedback on trying this?
Old Feb 20, 2004 | 10:52 PM
d_warner's Avatar
Old Timer
The KA motor is totally different than the VQ motor.
Requirred
Remove intake (Upper and lower), Remove valve covers, remove all belted accessories, remove passenger side motor mount, remove outer timing chain cover. From there, you will be able to access the cams. Simply removing all the crap will take you more than 2 hrs easily. Look at a weekend to do this project.
Old Feb 20, 2004 | 11:29 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
LOL, swapping cams in an Inline-4 is about a zillion times easier than a V6. Also, there are differences on both cams between the DE and DE-K.
I did a little analysis in the other thread: http://forums.maxima.org/showpost.ph...2&postcount=59
Based on that (assuming I didn't get my numbers reversed), I think it would be worthwhile to try to swap a DE-K exhaust cam onto a DE with the MEVI since it would help with the top-end breathing a lot more. Heck, a DE-K exhaust cam onto a DE intake cam might be worthwhile also.
So long as you can get the cam aligned properly. Wow that would be confusing.
Old Feb 21, 2004 | 04:20 PM
nismology's Avatar
You finally broke it down like you promised you would.
What I meant by the intake cams being the same is that the intake valves have identical lift. I should've specified. And I don't know where I got those overlap numbers from either.
But as for the DE-K cams having more lift...Won't the fact that they have less duration negate the added lift?? Teach me o wise one...
You're my tech hero
Old Feb 21, 2004 | 04:58 PM
SteVTEC's Avatar
Only the DE-K intake cam has less duration.
VQ30DE
Intake Valve Open: 3 BTDC
Intake Valve Close: 49 ABDC
Intake Valve Duration: 232
Valve Lift: Nominal
Exhaust Valve Open: 49 BBDC
Exhaust Valve Close: 3 ATDC
Exhaust Valve Duration: 232
Valve Lift: Nominal
VQ30DE-K
Intake Valve Close: 41 ABDC
Intake Valve Duration: 224
Valve Lift: Nominal
Valve Lift: Nominal + 0.525mm
You wouldn't want to swap a DE-K intake cam onto a DE. The thing of interest is the exhaust cam which has equal duration (232*) but slightly more lift. Swapping a DE-K/exhaust onto a DE/exhaust would be interesting to see, especially with the MEVI, or even "reverse" swapping it onto the intake side if you can figure that out. If the KA guys have done that successfully then there's no reason it can't be done on a VQ.
Does anybody know the actual valve lift specs of the DE or DE-K cams? What the FSM gave is the entire height of the cam including lobe which is not the actual valve lift. I'm sure somebody here knows this. I should probably also try searching.
Old Feb 21, 2004 | 06:33 PM
krismax's Avatar
Father of the 00 VI
I dont know much about cams but how do taking the best cams from both engines measure up to the JWT cams.
What do you think?
Old Feb 21, 2004 | 06:59 PM
SteVTEC's Avatar
The JWTs are way more aggressive - no comparison. I can tell that having heard a few without even knowing the specs. Any factory cam these days is going to be pretty mild due to emissions and economy concerns. For reference, back in the musclecar era (60's to about '72) a lot of the engines back then ran maybe 260-280* duration cams stock, some even 300* or more, with crazy amounts of lift and 11:1 or even 13:1 compression. These little 232's are real dinky compared to back then or any aftermarket cams today.
Old Feb 21, 2004 | 07:30 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
From some source I got that stock VQ30DE cam exhaust/intake lift is 8.59mm. And the JWT VQ30DE cam lift is 10.54mm. I just dont remember where I got that info from, so im not sure...
Edit: Ok I found it. It was a posting my Mardigrasmax...
Old Feb 21, 2004 | 08:40 PM
Also if its worth anything I ran a simulation on Dyno2000 and it showed some tiny high rpm HP gains if you use VQ30DE-K exhaust cams in a VQ30DE motor. However using both VQ30DE-K intake and exhaust cams on a VQ30DE showed some decent gains on TQ but some loss of power on the top end, if thats true maybe the power loss is negated by the DE-K dual runner manifold.
Steve does this work at all with your theory?
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
TheMafia
Sep 4, 2015 08:26 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
