HELP!!!!! door light
i was changing my bulb for the driver side door light.
and it was hot and i tried taking it out using screw driver....(stupid me)
and after that even thou i replaced it w/ new bulb(tried 2~3 other bulbs too)
and checking the fuse under the steelingwheel.
still it wont light up
but doom and the passenger side door light works fine...
im so lost....
can someone help me with this?
any idea?
im so lost....
any idea?
I was looking into it, I also have the same problem. In the FSM it says they have there own fuse, the door lights are ground driven, so they are laways hot, I have yet to find the inline fuse tho...
Originally Posted by Silvia
still cant find fuse??
I don't think is a fuse problem, I had the same problem with my door light. This happened like the first week I got my car out of the dealership. I changed the bulb to Xenon White bulb and after putting the bulb in the passanger door light would not go on. So I cheked the Fuse and everything look good. I made a appointment with the dealer ship took the car for repair. I am not sure what it called, but it was a Black Box rectengular shape, the mechanic said it cost about 80 bucks, that went bad, it was like some type of relay something like that. Just go to the dealer ship and ask for relay in the door for the light. they would print a map and tell you what it is. I don't know how much help i can be. Good luck.
I had the same problem one month ago. I was installing an LED in the door and when I was the LED blew so i put back the original bulb and nothing. I tried two brand new bulbs not LED's and still nothing. I installed an LED in the passenger door and it works fine. I dunno what the problem is. Where is that little black box located?
Let me ask you something does yoru power window working? because mine stop working as soon as the light stop working......
everything works fine on mine other then just that one bulb .... and hmm i think that Switch Assy-Pow. part number 25411-0L700 was for the power window
i have the same problem. i took the door panel off and i tested it with a power tester thing. and it was still getting power but the ground got messed up. i think by using a screw driver it messed up the ground. i dont know how but i think thats what happens. one of thse days when im bored im goin to cut the wire and relocate the ground.
My door light is not working either...I was installing a led light in my door, and spliced into the door light. After that the door light doesn't work, and the led bulb lights up very dim. I then attached a wire to ground and to the negative side of the bulb and it lights up bright! So what do I have to do to fix this?
im so lost....
any idea?
im so lost....
any idea?
hmm driver side window swtich???
hmmmmm....
i went to a nearby nissan dealer and they have no idea whats causing this....
awwww this is like biggest mistery
hmmmmm....
i have the same problem my 1 light nuthin else they guy at car quest said it was a wiring problem like the wires get opened up from the door being opened like a milion times and it touches other metal but i dunno if i believe that
It's giving me a wierd voltage too. After screwing it up the socket runs 12v when the door is closed, but only enough amperage to light up the LED’s very faintly, and 8v with the door is open. As apposed to 0 when closed and 12 when open.
dont have extra set of window switch
MaxLife17
Jun 27, 2019 01:37 PM
Maxima30
Sep 7, 2015 06:13 PM
on the sticky
