Jerky Throttle Response
What are the general symptoms I should look at if I have a jerky throttle. I just need to know what to clean or change. Basically when I go from no gas, to pressing it, it kinda jolts the car a little.....never driven a car that does this before. I've done regular maintenence, throttle cleaning regularly, cleaned IACV, normal idle.....What could this be?
Originally Posted by PoePoe2797
ttt...why is it that no one likes to respond?
Plugs are new, coils should pop a CEL but I have no codes, I use 91 octance sometimes 93 if gas prices go down but it doesn't matter which gas i get. I have a jim wolf intake, recently re-oiled, and I ran a bottle of Chevron and Redline cleaners not too long ago....
I bought Denso...replaced no more than 1000 miles ago. About the oil, some other people told me that too so I cleaned the MAF and still the same. FYI, the problem was there also before the plugs were changed and filter reoiled. Also got now motor mounts so that can't be it
What did you use to clean the MAF? What you are describing points to a bad MAF. If you over oiled the POP and got a significant amount of oil on the wire in the MAF it may never come off. The wire gets hot and the oil will bake on.
Electronics cleaner....this was happening before I re-oiled the filter. And as I understand, everytime you turn off the car, the wire element is supposed to heat up to over 1000 degrees for a short period of time to completely burn off and contaminates on the wire
