Are JWT cams ok for forced induction?
Old Feb 26, 2004 | 12:17 PM
SupermaxGxe's Avatar
I am thinking about dropping the JWT cams into my engine soon, I also plan on going turbo though. Are these cams ok for turbo, I have on idea why they wouldn't be but just checking.
-Chris
Old Feb 26, 2004 | 12:18 PM
Conrad283's Avatar
I need a truck
What other mods do you have?
Old Feb 26, 2004 | 12:20 PM
mrnock's Avatar
i dont think they'd work. you're better off asking in the supercharged/turbocharged forum
Old Feb 26, 2004 | 12:24 PM
None as of now because it's a second engine that I'm building. It will have UDP, MEVI, JWT Ecu, headers, bigger injectors, cat-back system (not sure which one), and possible cams. This will all go on at once.
-chris
Old Feb 26, 2004 | 12:52 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
ummmmm, if i remember correctly, the JWT cams are made with the intention of being used in a N/A car, not a boosted one. Therefore, you'd see better gains on a NA car, with little, no or (gasp) a loss of power on a boosted one.
It's a good idea to ask in the S/C forums, or ask Nealoc, i'm pretty sure he has some in there.
Old Feb 26, 2004 | 12:54 PM
Ok, I'll ask.
-Chris
Old Feb 26, 2004 | 12:56 PM
Sin's Avatar
Sin
The JWT cams will most likely be incompatible. Aftermarket performance cams are usually more aggressive in terms of late intake throttle closing, early exhaust port opening, and are tuned for higher rpm as well. Because of this, with boost, you will probably boosting right through the combustion chamber quite often, as opposed to boosting air into the combustion chamber.
Old Feb 26, 2004 | 12:59 PM
Hmmm.... Makes sense.
Old Feb 26, 2004 | 03:04 PM
Torgus's Avatar
cams are known as the black magic of fi. they can either rock or blow ****. <--another orger said this and others agreeded with him a month or two ago...
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
Mahmuth
Sep 25, 2015 10:08 AM
A32goldylocks
Sep 2, 2015 06:39 AM
