starting issues
Old Feb 27, 2004 | 10:08 AM
A5295's Avatar
starting issues
I am having trouble when i start my car. It'll spin over three or four times, and then its like it hangs, or the batt goes dead. i can cut it off, turn it back on, and it may start the next time. there is no click, but more like its dragging. I am going to clean my batt terminals, check my connections, and possibly replace my batt cable ends. Do you guys have any other suggestions? I am worried that it may be the starter trouble that i have seen others have on the .org. It could also be my ignition switch, as it feels a little loose. It really bothers me that i just spent all this money to get my max back, and am now having trouble with something else...
please help me...
Michael
One more thing-if the starter is bad, would it interchange with another vehicle, like a pathfinder or something?
Old Feb 27, 2004 | 10:53 AM
DoNcHoYaX1's Avatar
just go ahead and change the starter. Check your battery, might be going bad. But if your going to change the starter, just go with a new or should I say rebuilt starter from the autoparts.
Old Feb 27, 2004 | 11:18 AM
A5295's Avatar
that starter isn't to hard to replace, correct? it doesn't look bad anyway...i will have my batt and alt checked, as she is beginning to whine a bit... I will prolly try replace my batt cables too...
Old Feb 27, 2004 | 11:26 AM
maxima105's Avatar
I would have someone check the charging system first....battery, alternator, etc... Go by Autozone or Advance Autoparts and let them check it, they'll do it for free
Old Feb 27, 2004 | 09:39 PM
A5295's Avatar
Well, i checked my batt, and noticed that it seemed to have been leaking. I replaced it because it tested and showed to be bad. I replaced the ends on my batt cables, and checked my plugs...My plugs are very very well used...they have 124-125k on them. the electodes are pointed, but the car seems to be running clean...I had a set ordered, and at 54 bucks, think i got a decent deal...what do you guys think?
oh, and none of this changed the way the car acts when started, it just seems like the car is stuttering instead of trying to start...the hanging is not as bad, but still occurs...
Old Feb 28, 2004 | 06:14 PM
I30LeNnY96's Avatar
I also have starter problems but only in cold weather. Usually in cold weather my car wont start without my foot on the gas.
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
trungg86
Sep 4, 2015 04:58 AM
