How to change starter
Old Mar 13, 2001 | 11:58 AM
clee130's Avatar
Dangit... search won't bring up the "old" posts...
I know this was covered recently that someone had to change his starter and there was a link to a webpage where it showed you how to do it step-by-step.
Anyone know that link?
Old Mar 13, 2001 | 12:28 PM
Daniel B. Martin's Avatar
Starter replacement is a job which can be done by the home mechanic.
No need to jack the car, the starter motor is accessed from above.
Remanufactured units are available for $140 (Brand X) up to $360 (Bosch).
If done by a professional the labor charge ought to be one hour.
Make written notes of the radio station presets. Disconnecting the battery will cause the radio and clock to experience "amnesia".
1. Disconnect the cable from the negative terminal of the battery.
2. Remove the air intake duct and the air cleaner housing assembly.
3. Disconnect the battery cable and the solenoid terminal connection from the starter solenoid.
4. Remove the two starter motor mounting bolts and remove the starter from the engine. These bolts may be really tight!
Installation of the starter is the reverse of steps 1-4, above.
Set the clock to the correct time. Refer to the notes made in step 1 to restore the radio station presets.
For more information (and photos) go to http://vbxmaxima.8m.com/starter.html
user 11122324
42
Jul 18, 2022 03:35 PM
Excalibur23
Oct 13, 2015 04:33 PM
msellas
Sep 23, 2015 09:16 PM
homewrecker
Sep 23, 2015 03:41 AM
