Started problem, not really the starter
Old Feb 27, 2004 | 08:08 PM
MDeezy's Avatar
Hello Maxima drivers
first I have a 96 Maxaima SE, all stock ( for now. . .)
I am having a problem, My car was having a difficult time starting, I would go to start the car, and it it would struggle to start but then start. At first I was told it was my starter, and that I would need to get a new starter, then I was informed it could be my battery not turning to the started over fast enough, So I got a new battery and it didnt fix the problem. TODAY I got a new started from advanced auto parts and the first time doing somewhat serious work under the hood and fourtunately I was able to change the starter and put in the new one, started up the car hoping that would solve my problem but it didnt, my car still drags when its starting up does anyone know what the probem may be? My friend though maybe the distrubutor or a bad sparkplug? What do you guys thinkg, it may be?
Old Feb 27, 2004 | 08:12 PM
Johnny01001's Avatar
bad sparkplug
Old Feb 27, 2004 | 08:25 PM
MDeezy's Avatar
how can I tell if a spark plug is bad?
What tools do I need to check my spark plug?
Old Feb 27, 2004 | 09:30 PM
dmplus's Avatar
They're cheap enough that if you bother to pull them out you may as well put new ones in (unless they are fairly new) Pull a copule of them and look for abnormal wear, deposits, gaps etc...
Just need allen wrench to remove the engine cover, phillips screwdriver to remove the coils, and ratchet set with extension and plug nabber (whatever it's called )
Shouldnt take more than 10-15 min to check a couple, 30-40 min or so to swap all for new.
Old Feb 27, 2004 | 09:48 PM
MDeezy's Avatar
thanks I'll check them out tommrow, its dark now, I'll check and see what tool I need, and get it.
thanks, I hope its my spark plug and end this, I want my max to start up first try. . .
Old Feb 28, 2004 | 01:33 PM
MDeezy's Avatar
Well I got up this morning to start my, my Max dragged like it did usually, then I tried it again and she started flawlessly a little hesitation ( like normal any other car would) started her about 5 times during the day and I shes started like normal, its good! so I'm going to check my spark plugs ( going to get the platinum tipped kind) and change those if necessary but the new started is working.
I guess using the new started in the night, or in the cold the started needed some heat not sure, but its working nicely.
thanks all.
Old Feb 28, 2004 | 02:44 PM
Prodeje79's Avatar
Spark Plug Diagnostics
Dirt Bike Link: http://www.mztech.fsnet.co.uk/workshop/wrk_plugs.html
1975 Everything you ever wanted to know about sparkplugs: http://www.ingfatrygg.se/Spark_plug_diagnostics.html
HOpe that helps, I had one link that is really good, but I could not find it. :<
I would get copper if I were you. Do not waste your money on platinum.
You can get all 6 coppers for the price of one platinum.
There are tons of posts on copper plugs.
Old Feb 28, 2004 | 03:13 PM
MDeezy's Avatar
thanks very much Prodeje79 that is very helpful I'm going to read it before changing my spark plug so I know what to look for
Great link.
WIth the money I hopefully will save that means Altezza lights on the back of the Max (hehehehe)
THanks
Old Mar 1, 2004 | 08:31 AM
Prodeje79's Avatar
Great link.
THanks
No Problem!
Here is that other link I couldn'y remember from Turbo Regal:
http://www.gnttype.org/techarea/engine/plugs.html
I also wanted to post so that I was not on post 666 anymore ehehe
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
trungg86
Sep 4, 2015 04:58 AM
