AE headlights - can't get assembly out!
Old Feb 28, 2004 | 01:48 PM
my99maxisnice's Avatar
Someone help me get the headlight assembly off of the car please. Both writeups suck as far as taking them out, and even the Haynes Manual doesn't help. I can't find the 4 bolts. IF anyone can give me a verbal explanation, or pictures would be better. Thanks in advance.
Ryan
Old Feb 28, 2004 | 03:31 PM
bump bump it up up
Old Feb 28, 2004 | 03:38 PM
Conrad283's Avatar
I need a truck
Getting the headlight out.
Once the corner light is out there are two 10 mm bolts. Those must come out. There are two nuts on the inside (towards the middle of the car, next to the radiator) Then remove the bulb and place it in a spot where it won't be touched or broken. And just pull it out.
Old Feb 28, 2004 | 04:02 PM
I'll check it out in a bit. Thanks a bunch.
Old Feb 28, 2004 | 05:59 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
the headlight comes off easier if you remove the grill.
Old Feb 28, 2004 | 06:10 PM
1FSTMAX's Avatar
Hahhahahah yes it does.
Once you remove the front grill, and the clearance light you can have easy access to the nuts. You will need to a deep well socket.
Old Feb 28, 2004 | 09:26 PM
ManualMaxima's Avatar
5th Gen till she dies!
yea haynes manual sucks.....i ave it and it was a waste of money..... while you are at it paint the corners too......paint the whole thing on the inside just not the trim pars it looks muchh better like that.
Old Feb 28, 2004 | 10:26 PM
Ok I did it. Just got finished at 2 AM...i took my time. When putting the lights back on, I dropped a short extension down in my engine somewhere, but it didn't fall through to the bottom...hopefully it isn't life threatening.
Old Feb 28, 2004 | 10:39 PM
Jepht20's Avatar
Custom User Title...
it prolly landed on the black plastic splash guard shielding underneath the engine.
how'd it turn out??
my buddy mendon11 is gonna be doing that tomorrow. i would but i think it would look bad with my 95's glass headlights.
Old Feb 28, 2004 | 11:00 PM
Taken2DaMax's Avatar
those nuts on the other side of the radiator are a bytch to get off. There is some steel line in front of the bottom nut that makes it he!!a hard to screw off. Gald you had no problems!
Old Feb 28, 2004 | 11:12 PM
IT isn't on the plastic shield, i hit it from underneath and heard no jingles...which somewhat scares me. At least my headlights look good
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
atriuum
Sep 28, 2015 01:19 PM
Noela
Sep 26, 2015 08:22 AM
