Are o2 sensors interchangable??
Old Feb 29, 2004 | 02:02 PM
paul2112's Avatar
I put a rear sensor where it wasn't supposed to go (before the CAT). I have a 99 Max. It's a long *** story, but will this sensor get damaged? Are these sensors built specifically for the place where they are placed or is the ony thing different about them the length of their wires?
The car runs fine, and I plan on fixing the mistake but not for a few days.
Old Feb 29, 2004 | 02:10 PM
eckohb's Avatar
i know the front two are interchangeable, and i believe the rear one is too...maybe im wrong, but i think you might be ok
Old Feb 29, 2004 | 02:15 PM
ptatohed's Avatar
Licensed to Spell
:o)
The two upstreams are interchangeable but the one downstream is unique.
Old Feb 29, 2004 | 02:16 PM
Jatan's Avatar
According to http://www.oxygensensors.com your front and rear sensors are different. If you look at the part numbers:
Front: Universal Walker $44.95 250-23000
Rear: Universal Walker $46.95 250-24000
The front has 3 wires (250-23000) and the rear has 4 wires (250-24000). The sizes of the sensors might be the same so I don't think it'll be damaged.
Old Feb 29, 2004 | 02:21 PM
RA030726's Avatar
I'm nutty for Nissans
How many wires does the rear O2 sensor have? The fronts are heated so they have 3 wires. I'm sure youre fine though.
Old Feb 29, 2004 | 03:01 PM
maxspeed96CT's Avatar
The original VQ...
Id did the same thing almost, i bought the front sensor instead of the middle one, then i just put the one that i replaced and was really a good sensor in to the sport of the broken one. The wire was alittle shorter but it workerd fine.
Now the one i bought new broke but i think its cause of me doing something wrond with my air fuel gauge i think, i dunno.
Old Feb 29, 2004 | 06:02 PM
paul2112's Avatar
How hard is the front right sensor to change? (bank 1 sensor 1) Anybody know?
Old Mar 1, 2004 | 07:34 PM
RA030726's Avatar
My bad i think all the sensors have 4 wires.
They are easy to change with the correct tools.
Old Mar 2, 2004 | 05:35 AM
paul2112's Avatar
Thanks for your replies guys. Did you guys notice on your cars that the right bank sensor conector does not plug in at the top of the engine compartment where the other 3 plug in? (in front of the manifold cover that says V6 on it.) I assume I am supposed to use the plug down below because there's no way the sensor I bought is long enough. It's only about 18 inches in length.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
