Bose Problems....
Old Mar 1, 2004 | 02:32 PM
Str8ballin's Avatar
Bose Problems....
I have a 96 gle with the bose, my problem is this when I first start my car my radio won't come on. I have to hit the power button every time. Also my memory doesnt work. Kind of annoying. The clock does not work either. I checked all the fuses there fine. Could it be a wiring problem? Has anyone else had this problem? My radio has never been removed as far I know.
Old Mar 1, 2004 | 04:25 PM
dmplus's Avatar
Sounds to me like your constant power is missing/malfunctioning. Have you had the car since new? Did it just start all the sudden? I'd pull it out and check the connections.
http://www.carstereohelp.com/stereoremovalNisMax2.htm
Old Mar 1, 2004 | 04:30 PM
97WhtSE's Avatar
Yeah the besti way is to take the radio out and check it out. Maybe it's just the radio but my friends max has a problem with the clock it only comes on when u hit it.
Old Mar 2, 2004 | 02:12 PM
Str8ballin's Avatar
I'll give it a try, to bad you have to remove so much to get it out
Old Mar 3, 2004 | 06:03 AM
jguillory's Avatar
Yeah, sounds like you're not getting constant power to the unit. First check your fuses - I think they're all in the fuse block (no in-line fuse behind the head unit). If that's not it it may be in the wiring behind the unit or in the unit itself.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
