Infinity Q45 throttle body...with PICS!
Old Mar 1, 2004 | 08:53 PM
maxima98vspec's Avatar
here is what i've stumbled one today, do you guys think it would work. I would have to custom make a bracket for it and hard wire the sensor..i haven't really compared the 2 like to sensors and all that but Q45 is like 3.5", yea i can stick my whole hand in there.............
Old Mar 1, 2004 | 08:54 PM
Old Mar 1, 2004 | 09:12 PM
DCM Maxima's Avatar
It looks like the TPS will fit though
Old Mar 1, 2004 | 09:13 PM
Nismo3112's Avatar
Custom User Title
I'm sure if you somehow rig up a TPS sensor from a VQ, it should work.
Old Mar 1, 2004 | 09:14 PM
that's what i was thinking also, now i don't remember but does the vq throttle body have any more sensors on it or is that it, i can't remeber how mine looks lol.
Old Mar 1, 2004 | 09:37 PM
Keith P's Avatar
Bolt compatible? Compare the resistence of the TPS, idle through WOT, with the stock. You might be able to use trimming resistors to adjust... Did you get the MAF also? I am thinking bore size restriction there. Might have to mod that also.
Old Mar 2, 2004 | 03:34 AM
96sleeper's Avatar
It has no cam for cruise control, and the TPS might not work correctly. The 2001 pathfinder TB will work fine, all you need is an adapter plate.
Old Mar 2, 2004 | 05:21 AM
I30tMikeD's Avatar
It's going to be way to big and impossible to port match to the intake manifold. The intake manifold cannot even be truely port matched to the pathfinder 70mm TB because of the wall size. One good thing about the pathfinder TB is that it matches right up with the MAF which is also 70mm. The Q45 is 77mm and your intake path will be 70mm MAF, 77mm TB, 68 mm ported intake manifold.
Old Mar 2, 2004 | 08:26 AM
who need cruise control...........i donno im going to give it try later on.....i need to get a adapter i know....but a tapered one and hmmmmm i donno i; just let u know how it goes...i didn't pay for it so it don't care if it goes to waste...
Old Mar 2, 2004 | 08:48 AM
Dave B's Avatar
Not DAVEB the parts guy
It's way too big.
Dave
Old Mar 2, 2004 | 08:53 AM
infinitiblast's Avatar
Remember its not always the size that counts..........
Old Mar 2, 2004 | 09:09 AM
Tatanko's Avatar
Bacon Lover
To truly take advantage of this you'll need a custom intake manifold and an even larger MAF...
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
doctorpullit
Mar 29, 2016 11:08 AM
JonBlz
Oct 5, 2015 06:02 PM
