Starting Problem
Old Mar 2, 2004 | 02:27 PM
XoPtOn's Avatar
Starting Problem
this happens to me like once a week, it happened again today, i took a 5 minute ride because i had to order some tickets and when i get back to the car, i have no power, i put the key in and turn it and theres no lights or nothing, no starting noise and etc... then i get out of the car and lock the car and then i cant unlock it, i wait a few minutes while i keep on trying to unlock it and when i was about to use the key the unlock button worked on the remote. I open up the hood and it was pretty hot so i let it cool and i just played with the red and black wires to see if it had a good connection to the battery..... and then i wait 10 minutes and go inside and start the car. It starts normally but my radio stations were reset. Im thinking that this is a battery problem but i just bought it a few months ago...... can som1 share there thoughts about this?
Old Mar 2, 2004 | 07:55 PM
cam_honestiam's Avatar
Sounds like either a bad ground or a bad connection. You could also have a loose or half-blown fuse. Check all wires that lead from the battery to make sure they are not only tight but well-protected. Double-check the appropriate fuses underneath the dash and under the hood by the battery.
Old Mar 2, 2004 | 08:48 PM
Maxima99SE's Avatar
will fly for food
yea like cam said, it sounds like something is loose.....connection or ground
Old Mar 3, 2004 | 04:56 AM
XoPtOn's Avatar
oh okay, thanks guys
matts95max
Apr 23, 2025 10:44 AM
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
trungg86
Sep 4, 2015 04:58 AM
dcardello
Sep 3, 2015 11:44 PM
