Funny Idle after ECU check
Old Mar 2, 2004 | 06:58 PM
nissanlover's Avatar
Ok so I checked my ECU for the first time and was pleased to see that I got 0505 or nothing really wrong. So after that I went in and waited till I had to go to work. When I started the car it didnt want to start but then it did and a cloud of smoke came out. I got the car running, but the idle is really really low from the usual 700 to about 250. Then it jumps up and down from 250-500. I can hear the engine whining a bit as if it is sucking for air and the RPMS as I said keep hoping from 250-500. There is also a weired noise I believe from the the idle being so low. I think it affecting the performance as well. I talked to a friend who is a mechanic and he said that maybe I need to remove the battery cable for 30 mins and then check in hopes of reseting the computer. So I did that to no avail, but he said maybe I have to wait for 2 days or so of normal driving and it would reset itself. Also the car shakes when the idle is low, I am guessing because it is so low. Any help or advice would be great. Thanks
Old Mar 2, 2004 | 07:04 PM
I30tMikeD's Avatar
make sure you have the screw on the ECU fully turned back to the correct position.
Old Mar 2, 2004 | 07:06 PM
I believe I do I went back to it was snug, if I did not would that have affected the idle?
Old Mar 2, 2004 | 07:17 PM
I30tMikeD's Avatar
Yes it will affect you idle, you could have it turned snug the wrong way...just check it. It may also cause a strange ticking noise from the IACV even when the car is off and the key is turned to on. I had my screw in the wrong spot for a month and could not figure out what was wrong.
Old Mar 2, 2004 | 07:23 PM
Thanks I checked it again and turned it back again and it worked I believe the idle returned to normal hopefully tomorrow it will still be ok. Thanks for the help.
Old Mar 2, 2004 | 11:34 PM
-=PK=-Maxima's Avatar
lol this happened to me too..........you didnt reset the ECU correctly. you skipped step #4 on the instructions
Old Mar 3, 2004 | 11:05 AM
I sure did. I got worried thinking that something major was wrong, turns out I was just an idiot. lol
gustavison
Oct 4, 2015 06:50 PM
bryants95max
Oct 2, 2015 12:52 PM
QueensMAX
Sep 15, 2015 04:14 AM
ballerchris510
Sep 10, 2015 09:35 PM
