HID's on 98 - Will I ever stop getting flashed??
Old Mar 5, 2004 | 11:11 AM
  #41
ABK's Avatar
ABK
I got an idea y don't you guys try to paint the bottom part of the reflector black?
Old Mar 5, 2004 | 01:32 PM
  #42
Jatan's Avatar
Originally Posted by 98se5speed
Yeah, I keep meaning to have someone else drive my car so I can see what they look like and how blinding they are, but my one friend who has a clue how to drive stick lives in LA.
At night just park your car on the street right behind a friend's car and leave your headlights on, then get in your friend's car and drive it slowly forward to see how other people feel when your car is behind them
I can't wait until I get tinted windows so those damn truck drivers can't blind me
Old Mar 5, 2004 | 01:47 PM
  #43
Wisky97SE's Avatar
HIDs in our 9004 housing are bright and annoying to others in traffic. Whenever I see a car with aftermarket HIDs coming towards me that have blinding lights, I just put on my highbeams and turn em off when they pass.
Old Mar 5, 2004 | 07:03 PM
  #44
formz
To the people who made the glare shields: Any tips on materials procedures or general how to's?
Old Mar 5, 2004 | 09:16 PM
  #45
Max Noob's Avatar
how much did you 5300k hid cost..i wont get anyhting more than 5500k..cause it gets bue after that..
open up your head ligths and black out some of the reflector AE style.. it will look clean and you'll stop getting flashed..just black out more than the normal front part.,.
Old Mar 6, 2004 | 12:10 PM
  #46
98MistSE's Avatar
I made the my glare shields using some thin sheets of aluminum that I had. ****Warning*****You will void your warranty (if any) if you do it the way I did.
I had to cut away some of the plastic that surrounded the 9004 base of the HID bulb with my trusty Dremel. I cut the aluminum to cover half of the bulb (trial and error) and curved it slightly. When it fit snug, I wedged it into the cut out that I had made in the base of the bulb. Make sure the alminum does NOT touch the bulb in any way and it is atleast 5mm from the bulb to allow air to circulate around the it.
This may not work for all bulbs if the base is not the same as mine. Also, this is probably not the only way it can be done. I did a lot of searching on www.hidforum.com for glare shields as well. Hope this helps and if I get some time, I will try to take some pictures of mine.
Chris
Old Mar 6, 2004 | 12:25 PM
  #47
formz
Yea if you could take pictures of the glare shield that would great. I have access to all the aluminum I need in many different thicknesses and grades so any advice on making them would be great, thanks.
Old Mar 6, 2004 | 12:27 PM
  #48
1FSTMAX's Avatar
Originally Posted by deezo
When I had my 6000K kit, I got flashed only on the highway. Now I have a Catz 4500K Hi/Lo kit and I don't get flashed.
Do you have pics of the Hi / Lo beam pattern? I have seen that the bulbs are shielded, but are the shields for beam pattern correction? or for the high beam?
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
dshinn
Sep 26, 2015 08:07 PM
